Feature Description:
Many users (such as myself) have an Apple TV 4k (A1842 (32 GB)) running 12.1 tvOS and have it CEC enabled with a television & receiver. This makes for a simple 1 remote setup to turn on the Receiver, TV and Apple TV. It also makes for a simple 1 remote setup to turn off the TV, Receiver and sleep the Apple TV.
As a user, I would like to have Home Assistant support sleeping my Apple TV, which would thus turn off my TV & Receiver.
Currently the Apple TV component does not support this.
Operating environment (Hass.io/Docker/Windows/etc.):
Docker
Component/platform:
Only Workaround:
The only workaround presently is a convoluted sequence of left/down/select options in a script; which is not stable (often doesnât work).
apple_tv_off:
alias: Apple TV Off
sequence:
- data:
entity_id: media_player.onkyo_receiver_zone2
service: media_player.turn_off
- data:
command: top_menu
entity_id: remote.living_room_apple_tv
service: remote.send_command
- delay: 0:00:02
- data:
command: top_menu
- delay: 0:00:02
- data:
command: left
- data:
command: left
- data:
command: left
- data:
command: left
- data:
command: down
- data:
command: down
- data:
command: down
- data:
command: down
- data:
command: select
- delay: 0:00:02
- data:
command: down
- data:
command: down
- data:
command: down
- data:
command: down
- data:
command: down
- data:
command: down
- data:
command: down
- data:
command: down
- data:
command: select
Relevant configuration.yaml
entry:
apple_tv:
- host: 192.X.X.X
login_id: !secret apple_tv
name: Living Room Apple TV
start_off: true
Additional information:
Is it possible to begin integrating some of the latest changes from here?
Related Issues:
