I have two Apple TV’s at home. Both 4K versions. One is a little new the the other. The newest is from 2021. They both run the same software.
However, still I notice a lot of errors in my logs for the new Apple TV 4K. The 2021 version:
Logger: homeassistant.components.apple_tv
Source: components/apple_tv/__init__.py:227
Integration: Apple TV (documentation, issues)
First occurred: 15:41:50 (1 occurrences)
Last logged: 15:41:50
Failed to connect
File "/usr/src/homeassistant/homeassistant/components/apple_tv/__init__.py", line 227, in connect_once
await self._connect(conf, raise_missing_credentials)
File "/usr/src/homeassistant/homeassistant/components/apple_tv/__init__.py", line 329, in _connect
self.atv = await connect(conf, self.hass.loop, session=session)
File "/usr/local/lib/python3.11/site-packages/pyatv/__init__.py", line 155, in connect
await atv.connect()
File "/usr/local/lib/python3.11/site-packages/pyatv/core/facade.py", line 684, in connect
if await setup_data.connect():
File "/usr/local/lib/python3.11/site-packages/pyatv/protocols/companion/__init__.py", line 571, in _connect
await api.connect()
File "/usr/local/lib/python3.11/site-packages/pyatv/protocols/companion/api.py", line 143, in connect
await self._protocol.start()
File "/usr/local/lib/python3.11/site-packages/pyatv/protocols/companion/protocol.py", line 101, in start
await self.connection.connect()
File "/usr/local/lib/python3.11/site-packages/pyatv/protocols/companion/connection.py", line 80, in connect
await self.loop.create_connection(lambda: self, self.host, self.port)
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1085, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1069, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 973, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 628, in sock_connect
return await fut
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 668, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('192.168.2.41', 49153)
For some reason the newer version keeps giving problems when it comes to status checks, etc. Is there anything I can do about this?
