Apple watch actions doesn't trigger automations
Hi all,
I’m struggling with making my apple watch trigger automatins in HA.
info:
Home Assistant 2023.8.4
Supervisor 2023.08.1
Operating System 10.5
Frontend 20230802.1 - latest
apple watch version 10.0
I have two actions on my watch:
Garage toggle and open_door.
for the Garage toggle everything works fine - the autamation is working without any problem.
for the open_door, I can see it in the output of the event listener when I listen to ios.event_fired. if I trigger the automation manually from ha it’s working fine but for some reason the watch event doesn’t trigger the automation.
automation code:
- id: "open_garage_from_apple_watch"
  alias: "open garage from apple watch"
    - platform: event
      event_type: ios.action_fired
      event_data:
        actionName: "Garage toggle"
    - service: switch.toggle
      entity_id: switch.garage_door
- id: "open_front_door_from_watch"
  alias: "open front door from watch"
    - platform: event
      event_type: iso.action_fired
      event_data:
        action_name: "open_door"
    - service: lock.open
      entity_id: lock.core_mosquitto_front_door
example from event listener:
the event that works:
  actionID: BB4D85C9-EA01-4212-B0FA-E07EA95E8A95
  actionName: Garage toggle
  sourceDeviceID: itais_iphone
  sourceDeviceName: itai’s iPhone
  sourceDevicePermanentID: *******
  triggerSource: watch
origin: REMOTE
time_fired: "2023-08-29T18:58:29.389417+00:00"
context:
  parent_id: null
  user_id: *******
the event that doesn’t work:
  actionID: 274499D2-B78B-411D-9258-5C5946AD836F
  actionName: open_door
origin: REMOTE
time_fired: "2023-08-29T19:02:18.042462+00:00"
context:
  parent_id: null
  user_id: *******
thanks in advance!
Spelling mistake. That should be ios not iso.
thank you very much!!!
You’re welcome!
Please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has been resolved. This helps users find answers to similar questions.
For more information about the Solution tag, refer to guideline 21 in the FAQ.
