šŸ“³ Appliance Notifications & Actions - Washing Machine - Clothes Dryer - Dish Washer - ETC
Thanks so much.
I think I should have explained what Iā€™m trying to do better :slight_smile:
What I would like to do is, while the State is finished, but not emptied, turn on a red LED in another room, and have it turn off once it is emptied, Perhaps a custom action alongside the notification reminders would do it (just as the start watchdog and end custom actions work)?
With my limited HA experience, I think that I would be able to use a ā€œStateā€ for the whole automation, moving from running > stopped > emptied
Where I would do the following during the statesā€¦
Stopped (the machine is done running, but I have been lazy and not emptied it yet):
  • send notifications to devices
  • turn some LEDā€™s on
Finished (I have emptied the washing machine):
  • same as the End custom actionsā€¦
  • turn off the LED from the Stopped state
    ā€¦etc
Hopefully that makesā€¦a little sense. lol
Cheers,
tbp
@twobigpaws
Hi Andrew,
There are many ways to do this.
One way would be to use the custom end actions with the blueprint notifications.
In the end actionā€¦
  1. First you would add action and use turn on light. This will turn on your led.
  2. Then use building block and select wait for trigger and then add the trigger being you door contact sensor.
  3. Then add action to turn off light. this will turn off your led.
  4. Then add action and use notification then send your notification.
Do it in this sequence and you should get what you are after.
Hope this helps.
Blacky :smiley:
Hello there,
Iā€™m in two days, tried to did works but nothingā€¦
can you help me please?
The code:
alias: Monitoraggio Lavatrice
description: Test Blueprint Lavatrice
use_blueprint:
  path: Blackshome/appliance-notifications.yaml
  input:
    power_sensor: sensor.presa_smart3_power
    start_appliance_power: 5
    start_time_delay: 0.5
    end_appliance_power: 5
    end_time_delay: 0.5
    end_repeat_count: 3
    include_end_notify: enable_end_notify_options
    end_notify_device:
      - 008700965bf5213213e5ff82d1e08ea3
      - 1d126dd37c551441747f17a5bac1932e
    end_message_title: šŸ’§Lavatrice šŸ’§
    end_message: Lavaggio terminato !!
    include_power_tracking: enable_power_tracking_and_cost
    power_consumption_sensor: sensor.lavatrice_energy_meter_daily
    end_message_kwh: "Consumo: "
    end_message_cost: "Costo:"
    cost_per_kwh: input_number.costo_energia_casa
    include_duration_tracking: enable_duration_tracking
    end_message_duration_tracking: "Durata: "
    include_watchdog: enable_watchdog
    watchdog_timeframe:
      hours: 3
      minutes: 0
      seconds: 0
    watchdog_title: āš ļø Monitoraggio Lavatrice
    watchdog_message: Uh-oh! Forse devi controllare la lavatrice.
    include_custom_actions:
      - enable_end_custom_actions
    end_custom_actions:
      - action: notify.alexa_media_echo_dot_soggiorno
          message: La lavatrice dovrebbe aver terminato il lavaggio!!
          title: Lavaggio
      - action: notify.alexa_media_echo_dot_soppalco
          title: Lavaggio
      - action: notify.alexa_media_echo_pop_di_bruno
          title: Lavaggio
    include_time: time_disabled
    after_time: "06:30:00"
    before_time: "21:00:00"
    running_dead_zone: 2
@brunopiras
It is hard for me to help when I have no idea on what your power is doing through the cycle. Is your power settings set up correctly? The FAQ shows you how to set this up.
Maybe you can provide a zoom up screen shot of your power cycle graph so I can see what is happening. Also let me know what is going wrong and maybe use the start notify option to first set it up so you know it has triggered it at the start and then you can eliminate if it is the start trigger or the end trigger is the problem. Once you got it working you can disable it if you donā€™t want the start notification.
One thing I noticed is that you missed entering the 2 number helpers into Power Tracking > Power Tracking - Start Number Helper & Power Tracking - End Number Helper. The FAQ shows you how to set up these number helpers.
Blacky :smiley:
Thanks,
now, the wash-machine finish, Iā€™ve received start notification but nothing to the finish!
Here the code and Screenshot:
use_blueprint:
  input:
    end_time_delay: 0.5
    end_repeat_count: 3
    end_notify_device:
    power_consumption_sensor: sensor.presa_smart3_energy
    watchdog_timeframe:
      hours: 3
      minutes: 0
      seconds: 0
    end_custom_actions:
          title: Lavaggio
          title: Lavaggio
          title: Lavaggio
    start_power_consumption: input_number.powertrack_start
    end_power_consumption: input_number.powertrack_stop
    include_start_notify: enable_start_notify_options
    start_notify_device:
@brunopiras
In your power setting could you try a few things.
  1. Set your Running - Dead Zone to 0
  2. Set your End - Repeat Count to 1
Test it and see if that works. It is still hard to see your graph data.
Blacky :smiley:
@Blacky
Ok, I did !
Just to wait the next wifeā€™s laundry time :smiley: I think tomorrow morning.
ps:
Better graph power
@Blacky
Done!
It works very well, notify start and notify finished with additional informations like duration, cost.
Custom notifications (media player) works too.
@brunopiras
Perfectā€¦ nice to know it is working. This is one automation that I love and cant live without now.
Thanks for getting back to us and letting us know.
Enjoy
Blacky :smiley:
Hi all! how you config this if you have 2 or more variable energy cost? Thanks!!
@kilopter
Have you enabled the end notification.
Could you please provide us your YAML of the automation? This YAML code are the settings you have selected in the automation so I can help. To do this go into your automation, top right 3 dots, Edit in YAML, copy all the code, come back to the forum and in your reply at the top tool bar click on ā€œ</>ā€ and paste code in there.
Blacky :smiley:
thanksā€¦ already close the last postā€¦ due was an issue when activate the Power Tracking. having some issues with that partā€¦! heheh Thanks blacky
@kilopter
No problem.
You would still create your number helper then have a custom automation to change it for you.
Create a new custom automation > 3 dots top right > edit in YAML and paste the code below then in the Then do expand it out and in each of the action change it to your energy rate and your number entity ID.
NOTE: It takes the number at the end of the cycle so if it crosses over the cost is not accurate.
alias: Energy Cost
description: Energy Cost During The Day
triggers:
  - trigger: time
    at: "08:00:00"
  - trigger: time
    at: "15:00:00"
  - trigger: time
    at: "21:00:00"
actions:
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - data:
              value: 0.2
            action: input_number.set_value
              entity_id: input_number.electricity_rate
      - conditions:
        sequence:
          - data:
              value: 0.35
      - conditions:
        sequence:
          - data:
              value: 0.15
mode: single
Blacky :smiley:
yes!! more simple imposible:)
another questionā€¦ its possible to export the cost value or the consume to an entity?
If a load of laundry is costing you $11, you are doing it wrong.
@kilopter
Yes you can, but you would have to do it in the custom actions and record it to a number helper but that will only last for 10 days. You can do other things to record the data into HA but it is quite involved and should proceed with caution.
Regards the image of your notification, I not sure if your asking a question or just showing your notification. Because I donā€™t know your currency I am not sure if $11.17 is correctā€¦ it might be :thinking:. For me my electricity rate is 35 cents so my number helper must be 0.35 then it would be 0.09 x 0.35 = $0.03.
Blacky :smiley:
now works perfect!! thanks
Wow this is almost exactly what ive been looking for, and now i come cap in hand to see if anyone is able to help me on a journey to extend this blueprint a little.
What Id like to do is have a QR code on the washing machine or dryer that when scanned turns the power socket on and stores the details of the person that scanned it for targetted notifications once complete.
Once complete, grab these details and use them to notify that persons device and media players.
The rationale: I did set up something similar to this, but nowehere near as comprehensive and found that my teenagers didnt seem to mind if the entire house was being reminded over and again that someones laundy was ready to be tended to!
To that end, having a qr code on the machine that turns the socket off and kills the notifications would be in order, I reckon.
Complete newby here - migrating from homekit and loving what HA has done for our smart home so apologise for my pie in the sky hopes but hope someone is able to point me somewhere toward the right path. Cheers.
@tipananz
What you would do is create a simple automation that turn ON the washing machine when you scan the QR code.
Next, create a script that identifies the last device to scan the QR code and sends a notification to that device when your washing is finished. Use this script in the custom end action of your automation. Now, when the automation completes, it will notify the appropriate device.
You can also choose to turn OFF the washing machine within the script or add a separate action in the custom actions section to turn OFF the washing machine.
Blacky :smiley:
