Apps not installing
Im trying to get FrigateNVR up and running in HA and having issues.
Hardware: Windows 11 running on a Dell 5480
Set up: HA is up and running through VirtualBox. I was able to sign into HA and map the repository for FrigateNVR. I followed several guides for the VirtualBox and it appears to be working. I was able to sign into HA from my phone and see the same devices I can see from my computer. Both the computer and the phone are connected to the same wifi.
The issue: when i try to install MQTT and Frigate, I press the install button and it just continuously spins until i leave that screen and then the install button returns. when i try to install the apps from my phone, i get an unknow error and then the connection drops from my phone and the computer simultaneously and then an option to download a log file. I have downloaded the file and can share if that would help. this last time i just tried seems to have crashed the VM as well.
I have tried to install other apps that seem to be available and none of them install.
I have what I would call “enthusiast” level knowledge at best about networking.
Thank you in advance for any help!
Which version of homeassistent are you running? If it isn’t the 2026.10.4, then you are probably affected by a bug where GitHub changed the size of some headers. It is fixed now though.
Link to info: PSA: Why all updates are failing
Thank you for the quick help! Not sure if that was/is the issue but:
I’m using haos_ova-18.3.vdi and the start up screen says OS Version: 18.3. Now the VM is booting, but i cant log in through the web browser or app…welp solved that issue…i just learned that every time i restart the VM, it gets a new address. I need to figure out how to fix the IP address. looks like when i just relogged in, i’ts downloading a new version. Ill check back after this new version installs.
This is my version:
  • Installation methodHome Assistant OS
  • Core 2026.10.4
  • Supervisor 2026.10.3
  • Operating System 18.3
  • Frontend 20260930.5
So you are on the .4 release, are you able to download the apps now? If you aren’t, you need to get some info from the logs System Log - Home Assistant .
When using the setup in production / for real, you will definitely have to use a fixed IP, check if your network is bridged or NATed, there are different steps in how to do that.
