interesting,
1st: dont have this logline, i think i never updated
2nd: lifetime should not be carrying last_reset afaik
I also noticed the logline, I can confirm it’s there.
Did anyone update to HA 2021.11 already? Is the integration still working?
I couldn’t find any reference in the release notes about the deprecated ‘last_reset’ and was wondering of the change was truly pulled into this release.
I’m a little hesitant about upgrading to 2021.11.1…
Currently running core-2021.11.2 without any problems.
I’ve upgraded to 2021.11.3 without problems as well. The warning is still in the Log after startup, but I guess it doesn’t break anything (yet?).
What is the current status of support for ECU-R or ECU-C? Reading this thread I don’t quite get a clear picture of the current situation. Do both “gateways” work? Should one be preferred over the other for HA integration?
Can this integration/script also used for ECU-B?
It’s optically the same model as ECU-R, the data request could be the same.
No, this integration does not support the ECU-B unfortunately. This topic was allready covered here: APsystems APS ECU R local inverters data pull - #323 by HAEdwin
This subject is covered here: Yc1000 compatibility / ECU-C support · Issue #6 · ksheumaker/homeassistant-apsystems_ecur · GitHub
Thing is that I really took the time to dive into this compatibility thing but without owning an ECU-C, it is hard to get to the bottom of this.
@ksheumaker: I added a pull request
Fix for the energy dashboard thanks to @royvanmanen (issue #21 and #22)
WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.ecu_lifetime_energy (<class ‘custom_components.apsystems_ecur.sensor.APSystemsECUSensor’>) with state_class measurement has set last_reset. Setting last_reset for entities with state_class other than ‘total’ is deprecated and will be removed from Home Assistant Core 2021.11. Please update your configuration if state_class is manually configured, otherwise report it to the custom component author.
Thank you. I get the impression that ECU-R is better supported, or at least that the ECU-C is a tad unstable in that it needs to be restarted semi-frequently. I asked since I’m about to sign a contract for a solar panel installation, and have been offered en ECU-R, which I now feel comfortable with.
@HAEdwin, ksheumaker, CodingWerf : Thank you for your great work.
I installed my solar panels yesterday and set up the ECU-B.
Your AddOn reads all the data from the ECU and the inverter
So it seems to be compatible.
That’s great news, thanks for the feedback! This is with WiFi connection I assume?
@Apollon77 you might give it a new try. Compare firmware versions if it still does not work.
Yes, connected via WiFi in my local network.
The two LAN-ports are disabled by the manufacturer.
For your information, I have the firmware ECU_B_1.2.17009.
Did you see the message: { states(‘sensor.ecu_current_power’) | int - states(‘sensor.power_consumption’) | int }} {% else %} {{ states(‘sensor.power_consumption’) | int + states(‘sensor.ecu_current_power’) | int }} {%endif%}’ but no default was specified. Currently ‘int’ will return ‘0’, however this template will fail to render in Home Assistant core 2022.1
This is probably a custom sensor in configuration.yaml? Replacing the “int” instances for “int(0)” will solve your issue. This will default values to zero but is not recommended when you use conditional statements which use zero to trigger. I made one myself using float(0).
For those who have allready updated to HA 2021.12.0. You’ll find the following logline for inverter sensors: … implements device_state_attributes. Please report it to the custom component author.
As from version HA 2021.12 device_state_attributes is deprecated and should be replaced by extra_state_attributes. I’ll add this to the issue list on GitHub and add it to my pull request @ksheumaker. To solve this manually edit and replace two instances of def device_state_attributes for def extra_state_attributes in sensor.py
easy fix… thx… wasnt updated yet, Max took my attention today
also in binary_sensor.py btw? i do have it there too
Hey Sander, yes good practice to replace every instance. I noticed you were looking for the source of this deprecated info, it’s here: homeassistant.helpers — Home Assistant 2021.12.1 documentation
