APsystems EZ1-M / EZ1-D – Community Enhanced Integration (fixes log warnings, overnight unavailable & more)
Hi everyone,
I’ve been running two APsystems EZ1-M inverters (firmware 1.7.0 and 1.7.5) with Home Assistant for a while and ran into several bugs in the official integration that have been bothering me for a long time. I’ve put together a community-enhanced version that fixes all of them.
Fixed bugs compared to the official integration:
  • Sensors go unavailable every night – The inverter physically shuts down at dusk and disappears from the network. The official integration marks all sensors as unavailable. Fixed with a cache mechanism: sensors keep their last known values until sunrise.
  • state is not strictly increasing log warnings – The inverter occasionally returns slightly smaller lifetime energy values due to floating point rounding. Fixed by tracking the last output value so it can never decrease.
  • output_fault_status shows a problem every eveningnot c.operating with device_class=PROBLEM triggers a false alarm every time the inverter shuts down normally at dusk. Replaced with inverter_active using device_class=RUNNING with correct semantics.
  • Power limit always shows 800W – Fixed by calling the dedicated getMaxPower endpoint directly instead of relying on getDeviceInfo.
  • KeyError crash on newer firmwaremaxPower/minPower are missing from getDeviceInfo on some firmware versions, crashing the integration on startup. Fixed with safe fallbacks.
  • Python 3 syntax errorsexcept ConnectionError, TimeoutError is Python 2 syntax and causes a SyntaxError in Python 3.
  • Lifetime energy counter overflow workaround – Known firmware bug: the internal counter resets to 0 at ~540 kWh. The integration detects and compensates automatically.
New features:
  • Firmware version as diagnostic sensor
  • Separate today/lifetime energy sensors per PV input (P1, P2)
  • Comprehensive logging with meaningful log levels
  • German translations
  • EZ1-D support (max power read dynamically from device)
Tested with: HA 2026.3.1, firmware 1.7.0 and 1.7.5
Installation via HACS (custom repository): :point_right: https://github.com/shopf/apsystems-ez1-enhanced
Feedback, bug reports and PRs very welcome – especially from users with other firmware versions or the EZ1-D model!
Thanks a lot for your integration, it’s highly appreciated.
Just as a remark, I followed your migration steps to replace the official one with yours. But step 4 “deinstalling the official integration” is not possible as it’s not shown in the integration list anymore after the reboot.
Your integration seems to automatically replace the official one, at least that’s what I understand from “Benutzerdefinierte Integration, die eine Core-Komponente ersetzt”.
As I learned, starting with firmware 1.11.2, APSystems integrated a bluetooth lock. Is there a way to integrate a firmware update via Wifi into your integration?
Kind Regards,
meiser
Thanks for the feedback on the migration – good to know it works automatically! I’ll update the README to reflect that.
Regarding firmware updates via WiFi: unfortunately the local API does not provide a firmware update endpoint – updates are handled by APsystems’ own cloud infrastructure. This is outside the scope of a local integration. The AP EasyPower app is the only supported way to update firmware.
it’s a bit confusing that my inverter shows 135W power even though it’s shutdown. It also somehow falsifies the statistics.
Could the values for total power (Gesamtleistung), power of P1 (Leistung von P1) and power of P2 (Leistung von P2) go to 0 if the inverter is powered off?
Thanks,
meiser
@Osiris09, may I kindly ask to look at my issue?
Hi @meiser Sorry for the late reply. Please download v1.3.0; hopefully that should fix the issue. If you find any other bugs, please create an issue on GitHub. Thanks.
New sensors are now available:
  • DC voltage
  • DC current
  • Mains frequency and voltage
  • EZ1 device temperature
Hi @Osiris09, how did you get the FW 1.12.2? I try to install for the last 2 weeks, but it’s not offered in the app. Thanks for any advice!
There are different EZ1 hardware versions. If your EZ1 is older, version 1.10.2 may be the only one available as of today. Newer versions receive 1.12.2 or 1.12.2t. And then there are specific “battery versions” with completely different firmware designations. You can find more detailed information in PV forums, e.g. at www.photovoltaikforum.com
Thank you for this. I already made a bunch of helper sensors to prevent my panels from showing errors every night, but having it built in the integration is a lot cleaner.
One questions, I upgraded to this integration after my panels reset. But as expected, this fix only works if the rollover happens after upgrading. Is there a way to manually fix this afterwards? Essentially I want to add ~540kWh to the lifetime production of each panel and the total.
Hi @tim.bemindt yes, you can add the old value (per MPPT input) retroactively at any time.
In the device list, click the three dots on the right > select "Reconfigure," and enter the last known value into the "Lifetime energy start offset input (kWh)" field. For example, if you enter 540.62 there, the current counter will be increased by 540.62 kWh. I hope this helps :wink:
Yes, thank you. Exactly what I needed. Even the value was spot on, but I guess that's no coincidence. I wonder what number makes it overflow, I don't recognize a power of two or anything.
Thank you for the integration, working well for EZ1-M. Does it also support EZ1-H?
Hi @r.fitzgerald2004 I haven't received any feedback from an EZ1-H user yet. The datasheet shows a higher output power of 960W instead of 800W, which my integration should detect.
You are very welcome to give it a try and open an issue at any time if anything comes up. I would appreciate some feedback.
@Osiris09 I have installed yesterday 2 APsystems EZ1-D 1800w inverters with this integration and all seems to work well thank you.
Hey @r.fitzgerald2004 do you have an EZ1-H? Have you been able to try out my integration yet? Is everything working?
I’d really appreciate it if you could let me know whether the EZ1-H works — that way, I can add the device to the README. Thanks.
@tim.bemindt With the latest version (released today), you can now enter negative offset values ​​as well — which might be useful for very rare cases.
Just upgraded from the official integration to yours and it works flawlessly without doing anything. Using EZ1-H with latest firmware 1.12.2. Only problem is that it appears as an EZ1-M model otherwise everything is displayed properly. Thanks for the work!
Hi @spiderben25 thank you for the feedback. I've just released a new version and implemented automatic model recognition. From now on, the correct hardware designation will be determined and displayed for the following models:
  • EZ1-M
  • EZ1-LV
  • EZ1-H
  • EZ1D-L
  • EZ1D
  • EZ1D-H
If you encounter any problems, please open an issue. If it works flawlessly for you, a simple "like" on my post would be great feedback. Thanks.
