Hi there
I’m trying to ingest data from my APsystems solar panel
Panel information:
- EMA V5.5.0
- ECU 2160XXX
- Inverter Type DS3
I’ve tried 2 intégrations :
GitHub - bgbraga/homeassistant-apsystems: An APsystems Sensor for Home Assistant
setup seems to be correct but I’ve this in the log :
I’m not sure of the authId. don’t find any doc to understand where to take it -
Even in wifi or in wired i’m able to validate access with nc command :
nc -v 192.168.1.51 8899
nc: connectx to 192.168.1.51 port 8899 (tcp) failed: Connection refused
can someone explain me why wifi connection is needed ?
did someone has the same problem ? how did you connect your homeassistant to ECU or apsystems online ?
thanks for your help
have a nice day
