Done. I have switched to v1.2.10 and the system is up-and-running now.
No querying restrictions.
We’ll see what time will bring.
I’ll keep you posted.
Interesting posts. I have also had issues where my solar panels disappeared completely. I have downloaded the 1.2.10 version and will check tomorrow if panels are showing up again. Thanks!
Installing version 1.2.10 has not solved the problem.
After the upgrade, everything continued to work until 20:22.
At 20:22, the system became unavailable for 30 minutes, after which it became available again on its own.
At 04:26 the same thing happened until 05:42.
Ditto at 06:27 to 08:43.
What I noticed, in the short time that I used this the integration, is that every day at 08:43 the system became available again.
Frequently and throughout the night, still randomly goes to unavailable until… 08:43
unavailable 00:59 - 02:46
unavailable 04:26 - 05:42
unavailable 06:27 - 08:43
There seems to be some structure to it.
Last night, the ECU-R became unavailable at almost the same times, only 2 minutes difference.
For your information, the WiFi uptime of the ECU-R is 100% including the registration in the WiFi network.
Yes, mine is around ~2am that the ECU stops responding on port 8899 for a bit, but after that it comes back and the integration continues to work.
I’ve added the option to reconfigure the Integration afterwards. Please also update Translations. It’s recommended that you also update APSystemsSocket.py from my repository at: https://github.com/HAEdwin/homeassistant-apsystems_ecur
