Hi all,
I am trying to setup my first automation using the aqara button, I have copied the code from the guide and replaced it with my entities but it is not working, am I missing something?
This is what I have in the automations yalm:
- id: button_press
alias: Toggle Gateway light with button click
platform: event
event_type: click
event_data:
entity_id: binary_sensor.switch_158d0001ef3ad8
click_type: single
service: light.toggle
entity_id: light.buro
lolouk44
(lolouk44)
October 18, 2018, 8:59am
2
Could you format your code using the </>
button in the editor please? It makes it easier to see whether there are obvious syntax/indentation issues
lolouk44
(lolouk44)
October 18, 2018, 9:24am
4
Can you try this and let me know if it works?
- id: button_press
platform: event
event_type: signal_received
event_data:
Thank you for the suggestion but unfortunatly it doesn’t work.
I have turned on the log for the button and as far as I can tell it is working.
2018-10-18 11:29:18 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Switch_158d0001ef3ad8: off>: {'button_0': 'click', 'raw_data': [{'button_0': 'click'}]}
2018-10-18 11:29:20 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Switch_158d0001ef3ad8: off>: {'button_0': 'click', 'raw_data': [{'button_0': 'click'}]}
2018-10-18 11:30:45 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Switch_158d0001ef3ad8: off>: {'button_0': 'click', 'raw_data': [{'button_0': 'click'}]}
2018-10-18 11:30:50 DEBUG (MainThread) [homeassistant.components.xiaomi_aqara] PUSH >> <Entity Switch_158d0001ef3ad8: off>: {'button_0': 'click', 'raw_data': [{'button_0': 'click'}]}
Yoinkz
October 18, 2018, 9:47am
6
I’m also using the buttons from Xiaomi and I love them
Here is what I have and I can confirm that it is working
Xiaomi Button
- alias: Xiaomi Button
platform: event
event_type: click
event_data:
entity_id: binary_sensor.switch_xxxxxxxxxxxxxxx
click_type: long_click_press
entity_id: light.gateway_light_xxxxxxxxxxx
In this case I’m using the long press, not the single or double, but that can be changed to your matters.
Any luck?
Yes im really liking their products, its the reason I switched from vera to home assistant, when i get everything to work im going on a shopping spree
Anyway, I think my buttons version doesnt support long click, this is confirmed by the log file i think, it only shows single clicks and double clicks.
Tried it anyway but it doesnt work
Yoinkz
October 18, 2018, 10:06am
8
leendert:
Oh okay .
Do you know wha version you are using?
What about your gateway?
The button is the aqara second gen, the square one.
The hub is the third generation, the one with the AC function.
upgrading HA has fixed my problem!
After the upgrade the switch entity changed name for some reason, changed it in the config file and it worked!
(Changed from “binary_sensor.switch_158d0001ef3ad8” to “binary_sensor.switch_158d0001ef3ad8_2”)
