Aqara contact sensors became unavailable
As of 02-11 my Aqara contact sensors became unavailable.
Even after removing and add again they still wont work.
Someone any idea?
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2024.2.2",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.12.1",
    "docker": true,
    "arch": "aarch64",
    "timezone": "Europe/Amsterdam",
    "os_name": "Linux",
    "os_version": "6.1.74-haos",
    "supervisor": "2024.01.1",
    "host_os": "Home Assistant OS 11.5",
    "docker_version": "24.0.7",
    "chassis": "embedded",
    "run_as_root": true
  "custom_components": {
    "hacs": {
      "version": "1.34.0",
      "requirements": [
        "aiogithubapi>=22.10.1"
    "formulaone_api": {
      "version": "0.1.11",
      "requirements": [
        "requests>=2.20"
    "openmediavault": {
      "version": "0.0.0",
      "requirements": []
  "integration_manifest": {
    "domain": "zha",
    "name": "Zigbee Home Automation",
    "after_dependencies": [
      "onboarding",
      "usb"
    "codeowners": [
      "@dmulcahey",
      "@adminiuga",
      "@puddly",
      "@TheJulianJES"
    "config_flow": true,
    "dependencies": [
      "file_upload"
    "documentation": "https://www.home-assistant.io/integrations/zha",
    "iot_class": "local_polling",
    "loggers": [
      "aiosqlite",
      "bellows",
      "crccheck",
      "pure_pcapy3",
      "zhaquirks",
      "zigpy",
      "zigpy_deconz",
      "zigpy_xbee",
      "zigpy_zigate",
      "zigpy_znp",
      "universal_silabs_flasher"
    "requirements": [
      "bellows==0.38.0",
      "pyserial==3.5",
      "pyserial-asyncio==0.6",
      "zha-quirks==0.0.111",
      "zigpy-deconz==0.23.0",
      "zigpy==0.62.3",
      "zigpy-xbee==0.20.1",
      "zigpy-zigate==0.12.0",
      "zigpy-znp==0.12.1",
      "universal-silabs-flasher==0.0.18",
      "pyserial-asyncio-fast==0.11"
    "usb": [
        "vid": "10C4",
        "pid": "EA60",
        "description": "*2652*",
        "known_devices": [
          "slae.sh cc2652rb stick"
        "vid": "1A86",
        "pid": "55D4",
        "description": "*sonoff*plus*",
        "known_devices": [
          "sonoff zigbee dongle plus v2"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "sonoff zigbee dongle plus"
        "vid": "10C4",
        "pid": "EA60",
        "description": "*tubeszb*",
        "known_devices": [
          "TubesZB Coordinator"
        "vid": "1A86",
        "pid": "7523",
        "known_devices": [
        "vid": "1A86",
        "pid": "7523",
        "description": "*zigstar*",
        "known_devices": [
          "ZigStar Coordinators"
        "vid": "1CF1",
        "pid": "0030",
        "description": "*conbee*",
        "known_devices": [
          "Conbee II"
        "vid": "0403",
        "pid": "6015",
        "known_devices": [
          "Conbee III"
        "vid": "10C4",
        "pid": "8A2A",
        "description": "*zigbee*",
        "known_devices": [
          "Nortek HUSBZB-1"
        "vid": "0403",
        "pid": "6015",
        "description": "*zigate*",
        "known_devices": [
          "ZiGate+"
        "vid": "10C4",
        "pid": "EA60",
        "known_devices": [
          "ZiGate"
        "vid": "10C4",
        "pid": "8B34",
        "description": "*bv 2010/10*",
        "known_devices": [
          "Bitron Video AV2010/10"
    "zeroconf": [
        "type": "_esphomelib._tcp.local.",
        "name": "tube*"
        "type": "_zigate-zigbee-gateway._tcp.local.",
        "name": "*zigate*"
        "type": "_zigstar_gw._tcp.local.",
        "name": "*zigstar*"
        "type": "_uzg-01._tcp.local.",
        "name": "uzg-01*"
        "type": "_slzb-06._tcp.local.",
        "name": "slzb-06*"
    "is_built_in": true
  "data": {
    "ieee": "**REDACTED**",
    "nwk": 64371,
    "manufacturer": "LUMI",
    "model": "lumi.sensor_magnet.aq2",
    "name": "LUMI lumi.sensor_magnet.aq2",
    "quirk_applied": true,
    "quirk_class": "zhaquirks.xiaomi.aqara.magnet_aq2.MagnetAQ2",
    "quirk_id": null,
    "manufacturer_code": 4151,
    "power_source": "Battery or Unknown",
    "lqi": null,
    "rssi": null,
    "last_seen": "2024-02-11T14:57:42",
    "available": false,
    "device_type": "EndDevice",
    "signature": {
      "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4151, maximum_buffer_size=127, maximum_incoming_transfer_size=100, server_mask=0, maximum_outgoing_transfer_size=100, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
      "endpoints": {
        "1": {
          "profile_id": "0x0104",
          "device_type": "0x5f01",
          "input_clusters": [
            "0x0000",
            "0x0001",
            "0x0002",
            "0x0003",
            "0xffff"
          "output_clusters": [
            "0x0000",
            "0x0004",
            "0x0006",
            "0xffff"
    "active_coordinator": false,
    "entities": [
        "entity_id": "binary_sensor.lumi_lumi_sensor_magnet_aq2_on_off",
        "entity_id": "button.lumi_lumi_sensor_magnet_aq2_9f1de107_identify",
        "entity_id": "sensor.lumi_lumi_sensor_magnet_aq2_power",
        "entity_id": "sensor.lumi_lumi_sensor_magnet_aq2_9f1de107_device_temperature",
    "neighbors": [],
    "routes": [],
    "endpoint_names": [
        "name": "undefined_0x5f01"
    "user_given_name": "Aqara Contact Balkondeur beneden",
    "device_reg_id": "0181ac4d081e1698687e686111b7481f",
    "area_id": "woonkamer",
    "cluster_details": {
      "1": {
        "device_type": {
          "name": "undefined_0x5f01",
          "id": 24321
        "profile_id": 260,
        "in_clusters": {
          "0x0000": {
            "endpoint_attribute": "basic",
            "attributes": {
              "0x0004": {
                "attribute_name": "manufacturer",
                "value": "LUMI"
              "0x0005": {
                "attribute_name": "model",
                "value": "lumi.sensor_magnet.aq2"
            "unsupported_attributes": {}
          "0x0003": {
            "endpoint_attribute": "identify",
            "attributes": {},
          "0x0001": {
            "endpoint_attribute": "power",
            "attributes": {
              "0x0021": {
                "attribute_name": "battery_percentage_remaining",
                "value": 146
              "0x0033": {
                "attribute_name": "battery_quantity",
                "value": 1
              "0x0031": {
                "attribute_name": "battery_size",
                "value": 11
              "0x0020": {
                "attribute_name": "battery_voltage",
                "value": 30.2
          "0x0002": {
            "endpoint_attribute": "device_temperature",
            "attributes": {
              "0x0000": {
                "attribute_name": "current_temperature",
                "value": 1300
          "0xffff": {
            "endpoint_attribute": "manufacturer_specific",
            "attributes": {},
        "out_clusters": {
          "0x0000": {
            "attributes": {},
          "0x0004": {
            "endpoint_attribute": "groups",
            "attributes": {},
          "0x0006": {
            "endpoint_attribute": "on_off",
            "attributes": {
              "0x0000": {
                "attribute_name": "on_off",
                "value": 0
          "0xffff": {
            "attributes": {},
Zigbee2MQTT or ZHA?
ZHA with Home Assistant SkyConnect
It is just a wild guess, but could it be that the newly released OTA feature have updated them and they are now named something different?
Well, when i remove the device completely and add it again, it should connect with the new name, but it won’t.
I do not know if this give you anything, but try to go to the integration page and enable debug logging and then make a pairing and then click enable debug logging again.
You should not get a debug log downloaded.
all at the same time?
after an update or not?
what about your other zigbee devices if you have any?
do you use an extension cord for skyconnect? if not, you should,
and an you check the usb cable or another usb port?
aquara is not in the list of devices which will receive updates.
on my sonoff stick, all aquare door sensors are still working on the latest updates,
All at the same time! I used them for 2 years and yes, i use an USB cable.
I checked batteries (all oke). It’s a mystery :slight_smile:
Tonight i will start the debug options, see if i can find anything.
Do you have any ZigBee router devices? Maybe a chance they’re all running through the same router and that is the device that’s actually dropping off.
One option is to disconnect your ZigBee dongle for about 20 minutes to get the end devices to go into “search mode.”
After completely powered down HA, reset alle contact devices, remove and re-added the devices i gave up :frowning: and added an Aqara Zigbee hub (M2) to the network. Added all contact devices (with my phone) to the hub. Now using HomeKit in HA to add the devices to HA and everything is up and running again leaving me puzzled what is going on with the Aqara contact devices and ZHA (deconz) combination.
Thanks for the help and tips!
My Aqara window sensors have also become unreliable with HA 2024-02. The status when opening or closing is often not updated. It helps if I press the reset button, reconfigure, and then subsequently open and close the window. Using ZHA
Thanks! I will try this asap.
I got the same issue with ZHA and lumi.sensor_magnet
With the may release. It has been working fine for 2 years… Tried to reset, readd to Home Assistant, it works for a small number of hours before becoming unavailable again.
This sounds mostly like an update to the sensors that have extended their deep sleep length to increase battery lifetime and now the deep sleep is just longer than the time set in ZHA/Z2M to mark a device as unavailable.
I have exactly the same problem. More than enough routers in the house, the door sensor works perfectly just after pairing. But after some time it stops working. There is then no more link in the visualization of the topology and the status becomes ‘unavailable’.
I will try if it works better when the sensor is placed close to the coordinator.
I have the same issue with the aq2 contact sensors.
Has anyone had any luck in firmly addressing this issue?
It’s only fixable by replacing the sensors with the E1 version. Or replace all the incompatible routers in your house!
Thanks. I do not fully understand which type is which. I got these Aqara Tür - und Fenstersensor, Erfordert Aqara Hub, Zigbee-Verbindung, Drahtloser Detektor für Alarmanlage und Smart Home, Kompatibel mit Zigbee, Apple HomeKit, Alexa und IFTTT : Amazon.de: Baumarkt and chatGPT says that it is the “original model” while ZHA reports this string zhaquirks.xiaomi.aqara.magnet_aq2.MagnetAQ2.
Do you have a link to the E1 sensor?
By “routers” do you mean WiFi routers or ZigBee coordinators, e.g. ConBee?
sorry for my late reply!
i’m a father now, haha.
i don’t know which type it is either, but is sounds like the ‘wrong’ one.
by routers i mean zigbee devices with routing capabilities (not coordinators).
More info here and here
