I recently moved my raspbee II from the deConz integration to the ZHA integration and cannot get it to work properly. I did not have any issues like this in deConz.
Running Home Assistant Core 2021.12.5 on RPi 4b
Have updated all packages in venv to the latest release.
Have bluetooth disabled and raspbee II on ttyAMA0
When I add the raspbee II via ZHA it sets up the device however it gives the raspbee II an entity named “switch.dresden_elektronik_raspbee_ii_024e06ff_on_off” that I can toggle.
When I first add my aqara contact sensors they respond fine and quickly until I try to trigger them after they sit idle for around 30 seconds. After they sit the state changes do not register unless I toggle the random switch entity in the raspbee II device. Then the aqara sensor state changes register until they sit idle again.
This is the error logs I get upon first boot of Home Assistant. There are no errors that populate when the sensors stop responding or start responding again.
2021-12-24 03:51:59 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_indication (1, 1)
2021-12-24 03:51:59 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [28, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, 260, 6, b'\x18\x07\x0b\x00\x00', 0, 175, 221, 28, 182, 16, 0, 30]
2021-12-24 03:51:59 DEBUG (MainThread) [zigpy.zcl] [0x0000:1:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=7 command_id=Command.Default_Response>
2021-12-24 03:51:59 DEBUG (MainThread) [zigpy.zcl] [0x0000:1:0x0006] ZCL request 0x000b: [0, <Status.SUCCESS: 0>]
2021-12-24 03:51:59 DEBUG (MainThread) [zigpy_deconz.api] 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, ep: 1, profile: 0x0104, cluster_id: 0x0006, data: b'18070b0000'
2021-12-24 03:52:04 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0000:1:0x0006]: failed to get attributes '['on_off']' on 'on_off' cluster:
2021-12-24 03:52:04 WARNING (MainThread) [homeassistant.components.zha.core.channels.base] [0x0000:1:0x0006]: async_initialize: all attempts have failed: [TimeoutError(), TimeoutError(), TimeoutError(), TimeoutError()]
This is the logs when I enable and toggle the raspbee II switch entity.
2021-12-24 13:57:15 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=switch, service=turn_on, service_data=entity_id=switch.dresden_elektronik_raspbee_ii_024e06ff_on_off>
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy_deconz.zigbee.application] Sending Zigbee request with tsn 17 under 18 request id, data: b'011101'
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_request (18, 18, 0, <DeconzAddressEndpoint address_mode=2 address=0x0000 endpoint=1>, 260, 6, 1, b'\x01\x11\x01', 2, 0)
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy_deconz.api] APS data request response: [2, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, 18]
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy_deconz.api] Device state changed response: [<DeviceState.128|APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_INDICATION|APSDE_DATA_CONFIRM|2: 174>, 0]
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_indication (1, 1)
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy_deconz.api] APS data indication response: [26, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|APSDE_DATA_CONFIRM|2: 38>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, 260, 6, b'\x01\x11\x01', 0, 175, 221, 233, 0, 17, 0, 30]
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy.zcl] [0x0000:1:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=CLUSTER_COMMAND manufacturer_specific=False is_reply=False disable_default_response=False> manufacturer=None tsn=17 command_id=1>
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy.zcl] [0x0000:1:0x0006] ZCL request 0x0001: []
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy.zcl] [0x0000:1:0x0006] No handler for cluster command 1
2021-12-24 13:57:15 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0000:1:0x0006]: received 'on' command with [] args on cluster_id '6' tsn '17'
2021-12-24 13:57:15 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.dresden_elektronik_raspbee_ii_024e06ff_on_off, old_state=<state switch.dresden_elektronik_raspbee_ii_024e06ff_on_off=off; friendly_name=dresden elektronik RaspBee II 024e06ff on_off @ 2021-12-24T13:57:10.356884-07:00>, new_state=<state switch.dresden_elektronik_raspbee_ii_024e06ff_on_off=on; friendly_name=dresden elektronik RaspBee II 024e06ff on_off @ 2021-12-24T13:57:15.353993-07:00>>
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy_deconz.api] 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, ep: 1, profile: 0x0104, cluster_id: 0x0006, data: b'011101'
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy_deconz.api] Command Command.aps_data_confirm (0,)
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy_deconz.api] APS data confirm response for request with id 18: 00
2021-12-24 13:57:15 DEBUG (MainThread) [zigpy_deconz.api] Request id: 0x12 'aps_data_confirm' for <DeconzAddressEndpoint address_mode=ADDRESS_MODE.NWK address=0x0000 endpoint=1>, status: 0x00
2021-12-24 13:57:15 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0000:1:0x0006]: command failed: 'off' args: '()' kwargs '{}' exception: ''
2021-12-24 13:57:20 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0000:1:0x0006]: command failed: 'on' args: '()' kwargs '{}' exception: ''
