I am installing a no neutral double rocker wired Aqara switch. It looks like it is wired correctly. It was discovered in Zigbee. When I press the upper or the lower button, it toggles L1 (The first load, which is the porch light). It never activated L2 (The entry light). When attemtempting to add automation it shows up in device list double, with nothing to indicate which is the upper or lower button.
I am not sure if the switch is defective or I have not installed it correctly, or I have added the device incorrectly into ZHA.
Any help?
