Hi!
I have Aqara Dual Relay Module T2, connected to Aqara Hub.
I use it as with Dry Contact to open Garage door.
It works like impulse 300ms dry contact relay for both buttons
I also wish to use it in HA throu Matter integration.
It successfully recognised by HA as Light.
The issue is that when i press button in Home Assistant - it opens door, but switch change status to open (beside interval dry contact) - so wrong status in Home Assistant card.
What should i change?
