Aqara FP2 Node Red to Control LED Lights
Hi. This is my first time posting. I’m new to Node Red and having a lot of difficulty with using Node Red with my Aqara FP2 sensor in my family room. I don’t need to use all the zones for this flow. I simply want to check that there has been no presence in the entire FP2 area (any zone) for 30 minutes and then turn off the light switch to the family room. I’ve tried using event state, polling and other nodes to no avail. None of them produces the proper behavior.
Create a group of all the areas. Use the group entity in an event state node.
Ok how do you create groups?
Thanks. For any given flow, how do you restrict it to run only during certain hours. For example, I’m automating lights in a room to turn on but I only want this to happen in the middle of the night sort of like a night light. During the day we just adjust manually based on each family member’s preferences. I want this flow to only run between midnight and 6 AM.
