AQARA FP2 - not found
Hello guys.
New to HA and i try to connect aquaria fp2 sensor
I can see it in Aqara app and through aqara hub m2 I can not find it in HA or through zigbee
any help ?
I paired my to homekit to get them on the network then removed from homekit and they popped up in HA.
I did this but nothing in HA - I can see it only in Aqara app
Never used aqara app or aqara hub so can not help with that. The FP2 is designed as a HomeKit compatible device so you should perhaps delete those other things and just pair using your iPhone to the Home app. After it’s on the network remove it from Home app and pair using home assistant: homekit devices.
I am doing this exactly as you said but I see no notification in HA…
If homekit devices on the network are not auto-detected then you probably have an issue with mDNS discovery in your setup. Are you docker, supervised, HAOS? Do you have vlans for IoT devices?
I think I’m having the same issue. I just reworked my network to sequester my security cameras and IoT devices to their own VLANs for security purposes. I have my AP traffic tagged coming from the Aqara sensors and trunked through to my HAos (on a Pi4). I can ping each device with the Ping integration but I can’t add them to HA as a Homekit device. (I also don’t have an Apple device to attempt to add and then delete them from the Homekit App.)
Now I’m struggling to figure out how to set up mDNS/Bonjour on my Edgerouter and Netgear switch. Does anyone have any learning resources because I’m blindly poking around in the settings of both devices?
Didn’t quite understand your network topology from above but make sure multicast works across vlans. Also, you will need to add the FP2 to the network before HA can discover it - I am not aware of how you can do this without using an Apple device because I haven’t tried it without.
