Aqara FP2 sensors frozen
I’ve had an FP2 working well for about a year now. Recently all of the sensors stopped updating and the lux sensor went to a very high number. In the aqara app everything is normal, so I removed it from home assistant intending to reload it, but the homekit integration that could see it failed with an “unknown error” and showed nothing in the logs. Since then I updated core and now it doesn’t even find it on the network.
The aqara app still updates correctly, though the device blinks blue. I’m not sure where to go from here, but I’d rather not factory reset it and need to set up all of the zones and automations again.
Any advice would be helpful, I’m still just a novice. Thanks!
I can confirm the same problem, the graph suggest it is getting the latest data but it’s not reflected in the reported data.
As shown in the picture, the Lux level is reporting as 203, but currently the app shows it’s 5.
My FP2 sensors also seem to be frozen on HA but works fine on the Aqara app.
Reloading the device on HA updates the sensors to its current state and then stays like that. I just bought the FP2 a couple of days ago and it was working for about a day until the sensors stopped updating on HA.
Have tried removing device from HA, factory resetting the device, readded to Aqara app and then HA but still sensors are not updating.
Any other suggestions I could try?
