Hello All. I have an Aqara G3 camera hub successfully integrated using HomeKit Controller integration. this camera works as an hub, and when I configured the integration it successfully ported all bridged devices. I added a new device to the hub, and this does not appear in the list of bridged devices.
I tried to restart home assistant, I tried to restart the integration, I tried to use the “sync names” feature in the Aqara app. nothing worked. Is there anything I’m. missing? thank you very much for all your help.
Hello !
I would like to buy a Aqara G3 camera, but I want to check before that I can integrate it to home assistant. I saw this integration (https://github.com/niceboygithub/AqaraCamera), but it says that it does not support motion detection.
What I would like to be able to do is :
of course, streaming
ptz commands (does it work with the ONVIF integration?)
hide/show camera thanks to the physical shutter
do automations when motion is detected (records, snapshot, trigger alarm…)
When you say that you managed to integrate it with homeKit integration, are all of these commands possible?
