I have a Aqara G4 door bell
In HA there is 3 MUTE switch, what do they do?
Did you ever figure this out. I’ve got the same, though it won’t let me toggle any of them, and the first one is on.
edit: I can change the first one. That mutes/unmutes the repeater chime.
Also, have you found anyway to have the doorbell in the Aqara/Home app as well as in Home Assistant? I’ve found that if it’s in either/both of those, Home Assistant can’t find it.
I know I can add the entities to Home via HomeKit Bridge, but that doesn’t allow you to use the microphone to speak through the doorbell.
I did not figure out the use mute/unmute :-/
I have G4 in HA and on 2 android phones, so we can answar the door bell with the aqara app, and installed it in HA, to use the camera and when the button is pressed I have a chime on my google home speakers.
I’ve only got an iPhone, so unfortunately that won’t work for me.
If I could just have the doorbell in Home app and have it turn on an input_boolean switch when it was pressed, I wouldn’t need it in Home Assistant. But I want some scripts to run when the doorbell is pressed.
Unfortunately that doesn’t seem possible, and while I have it set up in HA at the moment, I’m considering switching it because I can’t save recordings in HA (camera.record isn’t supported).
Bit annoying that I can’t have it set up exactly as I want regardless of where it’s linked to.
You can set an automation for the triggers on “motion detected” & “motion no longer detected” in the Home app to create webhooks that go to your Home Assistant. Then you can create a more fully featured HA automation. Unfortunately, there is no Doorbell Pressed trigger. At least with this you can do something like: when motion detected webhook & I am not at home, then play alarm.
Unfortunately the motion detected bit is useless for me as I have neighbours in the next units that walk past a lot. It’d be triggered a lot for no reason.
I contacted Aqara tech support and they’ve said the passed the request to their team
