Hi everybody
I came across this on the aqara website.
Because i wanted to build a dimmer wit the aqara h1 switch. By holding the button. But it keeps disconnecting if i do that. Trough the aqara pairing mode when you keep the button pressed for 10 seconds.
6.What is the accidental deletion protection function?
The accidental deletion protection function prevents the device from being reset or unbound due to accidental operation. If this function is enabled on the Hub setting page, when the network is normal, long pressing the reset button will not reset the Aqara Wireless Remote Switch H1 (Double Rocker) or make it off-line
Is this function availible in zha or otherwise in zigbee2mqtt?
With kind regards,
Marc
