Aqara h1 button press not triggering automation
I might be mistaken but, I believe that unlike the wireless H1 switch, the wired H1 EU switch only supports single press. The long press on the H1 EU wired switches is used to delete pairing (from Aqara hub) and initiate pairing mode.
Smart Wall Switch H1 EU (No Neutral) - User manual - Aqara
EDIT: I found the article linked below, about the wireless switch and had a nose at the “Manage Zigbee Device” dialog for my H1 EU and it didn’t appear to offer a “click_mode” attribute.
Aqara H1 remote switch with Home Assistant - how to enable double/long clicks » The smarthome journey
You’re not. Only the wireless aqara switch supports long press.
I spent way too much time trying to get long press to work on my H1m and reached the same conclusion - long press on wired switches causes them to unpair
Just wanted to say thank you this worked perfectly for my switch, both left and right are working!
