Apologies if this has been answered, but my search-fu failed me if it has. Does anyone know if an Aqara H1 double-rocker will operate with only one switched circuit?
TL;DR - I have several with/without neutral H1s working well under z2m. I have one single gang dumb switch which I’d like smarten up. I could use the single rocker version of the H1 but wondered if a double would work with one circuit, which would supply power, but both switches in decoupled mode. A press of the first one would toggle the light, it’s long press and both actions on the second rocker would then trigger other things.
Has anyone tried this before?
TIA Dox.
