Aqara H1 Switch not reporting "action" or other values
I have had Aqara H1 (w/neutral, both double and single rocker) switches installed for a few months now.
Everything has been working perfectly, with a slight issue with setting “operation mode” after a Z2M update which was resolved in a Jan update.
Then, out of the blue one of my single rockers stopped working as intended.
I have 2 of these in the hallway controlling 1 set of lights.
1 is set up in relay mode. “master”
1 “slave” set up in decoupled, and an automation looks for “single click” action to turn on the “master”.
Both are wired in the same way.
Over the last few weeks the “slave” has been having issues with connectivity. It will drop off the network and blink red, I then have to put it back into paring mode and allow it to join again. Z2M says it has been configured correctly.
However Z2M no longer receives any updates. So i dont get the action any more “single click” / “double click”. I can turn it on and off from Z2M and set the “operation mode”. But thats it.
“Master” works as expected. Controllable and receives updates to Z2M.
Running on RPi4, HA OS install. Conbee II with a USB extension cable. OTAs for both switches show the same.
I am considering moving to a new coordinator (ZBDongle E / Sky Connect)
Any help / suggestions etc would be much appreciated.
Having the same issues, reporting it to zigbee2mqtt github
Added it to this issue in github: Xiaomi Aqara Knob H1 ZNXNKG02LM - incorrect attributes in reports (not during actions) · Issue #20968 · Koenkk/zigbee2mqtt · GitHub
Any luck with the issue? I am still getting the same.
Its strange because all switches work fine (ones further away from the co ordinator too). Even this one worked for sometime, then decided to stop working :confused:
I had something similar with one of my H1 switches and the fix for me was to update / flash the firmware on my Sonoff ZigBee Dongle-P to the latest version. After doing that the switches seem to work correctly again.
Might be something to try if you are not on the latest firmware!
Having the same issue - updating firmware for Dongle-P did not help. For me it used to work for quite a while and then stopped around 6m ago (I suspect after some zigbee2mqtt update).
Yep, read the breaking changes for Z2M 2.0 and greater.
You will need to enable legacy_action_sensor: true (also available in the z2m UI, so no need for yaml) if you want the action sensors back, since this is disabled by default from 2.0 onwards.
Alternatively, switch to using the MQTT device triggers or the new (experimental) event triggers as mentioned in the docs
Thanks for the reply, sadly legacy_action_sensor: true didn’t work for me.
