Aqara Home Assistant False Positives
I am new to Home Assistant on Raspberry but made my way through all the setups and created an email notification per aqara vibrate sensor, 6 sensors so far. Two temp sensors report correctly on highs and lows. The vibrate sensors if I tap it sends the notification but other devices on the same hub also say detected and send a notification.
I have removed the sensors from the hub (Aqara 2) and removed the hub from HA and Apple home. Once all reinstalled the same action occurs. I have two other hubs and devices but do not have this issue after the fresh install (yet). I’ve also changed the sensor battery and still have the same trouble with all sensors sending a notification based on “detected”. I’ve also tried changing it from detected to other options (vibrate/on/off options) but the behavior stays the same.
