Aqara Home assistant integration via Matter
Hey all, I already bound my M2 hub via matter to Home assistant and all the devices appeared in HA and work great.
My issue now is that i just purchased 3 leak sensors and bounded via the Aqra Hub but it doesn’t apear in HAS.
Do i have to unbind the Aqara hub and re bind it so it can see the newly added devices?
It would be a shame since all my Aqara devices in HAS are being used in automations.
I’m on the same boat, did you find any solution ? Thx
I binded a u200 to my m3 hub on the aqara app, then added the m3 to ha via matter, but it didnt also add the u200 into ha, is it normal? Because the way i read, in your case also the devices connected to the m2 hub were added at first…
After the new firmware update on the Aqara M2 hub. My leak sensors appeared as Matter leak sensors automatically. Apparently the sensors were not supported prior to firmware update.
