Aqara leak sensors will NOT pair to specific hub, range extender
Bought an Aeotec range extender, connected via z2m. Shows up in the z2m dashboard. I was then able to pair my troublesome rooftop terrace door sensor, and it automatically connected to the range extender. I can see the map showing a connection between the rooftop sensor and the range extender.
I’ve been having trouble connecting the master bath leak detectors, so I removed them in z2m, changed the setting in the z2m dashboard to only connect through the range extender. Put the leak detector into pairing mode. It paired, but weak signal, paired to the coordinator.
Tried it several times, removing and adding. Has anyone else had this problem with the Aqara water leak sensors?
