Hello!
I have configured Aqara M2 setup.
I’ve bought Raspberry and installed Home Assistant and it works great! Thanks!
I’ve found that I can connect Aqara M2 to HA using HomeKit Controller and everything is great but…
Finally Aqara M2 has possibility to export scene from Aqara App to Home App and I use it to control AC. This is the only feature of my Aqara setup that is not presented in Home App as a device but a scene.
My question is … will HomeKit Controller in HA find my scene if i choose to export this from Aqara to HomeKit? I do not want to try because I lose my current setup. If it wouldn’t work i do not want to setup this again without getting any extra feature.
I’ve figured out a workaround but only for the AC. Unfortunately my ceiling lamp is configured as a custom device in Aqara Home so it’s not visible in Google Home.
But if you have devices pre-configured (like my AC) in Aqara App then it should work.
Steps to setup:
Connect Aqara Home to Google Home.
Configure Google Assistant SDK in HA.
Create a script “Send text command” using Google Assistant SDK to send command “turn on the air conditioner”.
Thank you very much, worked for me, but also only with AC. And I’m still looking for a solution to add custom IR remotes to HA. Hope developers will add official Aqara integration with IR support
I finnaly found a way to do it.
Create your scenes on the Aqara app. Then go to your profile on the Aqara app and tap on connect to ecosystems. Then select home assistant and then Scene and signals sync and finally on Scene sync.
Then you can select which scenes you want to send to home assistant.
