Hi all, thanks to you support again!
I try to use the aqara motion sensor as a trigger. However i cannot select a the trigger entity… the drop down is empty.
(Gerät = device, Auslöser = trigger)
What do I do wrong?
Thanks a lot
What do I do wrong?
Thanks a lot
is the problem occurred, when you wrote LUMI lumi.sensor ?
have you tried with just the sensor-name lumi.sensor
… or just click gerätt , without typing anything
i.e it’s not an “entity” you look for, but the device most likely only the device name
edit2 " Motion Sensor " is what you look for … or what you named
