Hello
I’m not expert in wiring but I bought several switches with zero line (neutral port) and I discovered that all my lights switch has only 2 wires
Can I use the natural switches (N,L,L1) in my situation? How?
Hello
Not without a neutral. When you say two wires, is this to the switch or the total number of wires in the box. Neutrals are typically not connected to a switch but connected together in the back of the box.
If it is only 2 wires total, you’ll need a switch that works without a neutral.
I have only 2 wires
This means I can’t use the “switch with neutral ” ?
Any possible workaround? I already bought multiple switches with neutral
Unfortunately without bringing another wire to the box, no.
