There are some automation blueprints for this remote, but they all have some minor errors and are not updated. So I got the best of all together, tweaked and modified. Credits in the Description.
Iāve updated the blueprint to work with experimental Z2M events available on the dev branch and planned for Z2M 2.0.
Events have to be turned on in Z2M first to appear.
Thanks for this! I have to remake my switches after the update to Z2M 2.0 and move away from the old āactionā use. However when I try to use your blueprint, it just says:
Thanks @dawidxen , then I get the events I need! Worked
Question 2 - is there a good way to set up the āhold to dimā on lights? Iāve tried several setups, but I canāt get the brightness increase to repeat while the button is held⦠Have you done this?
Not sure if itāll stop automatically when button is released, I dont have a way to test it out at the moment.
If it doesnāt then thereās a release event that could break the loop.
You might also want to add a delay after brightness increase so it doesnt happen too fast.
It might be relavent but I canāt get any actions to trigger on āheldā items - actions work fine for single, double, tripple & release but not held.
Wonder if you are seeing the same that itās not actually hitting that step?
