I only manage to get the left 3 button working. None of the right 3 button are working.
Works like a charm!
Hi Guys,
I ordered the 6 button from aliexpress but got a 1 knob version ;-( Can somebody adapt/create a ZHA blueprint in for this single button, It is recognized by my converted sonoff. no knob action possible. thanks in advance… Frank
THis is the off action in zha_event
“event_type”: “zha_event”,
“data”: {
“device_ieee”: “04:cf:8c:df:3c:79:6c:d9”,
“unique_id”: “04:cf:8c:df:3c:79:6c:d9:1:0x0006”,
“device_id”: “5d49e31450bc29d225274e83fd90eaa0”,
“endpoint_id”: 1,
“cluster_id”: 6,
“command”: “off”,
“args”: []
“origin”: “LOCAL”,
“time_fired”: “2021-03-14T09:47:17.338883+00:00”,
“context”: {
“id”: “91df3969a376c0a4fb5c45474ecb72d8”,
“parent_id”: null,
“user_id”: null
and this the on action:
“data”: {
“endpoint_id”: 1,
“cluster_id”: 6,
“command”: “on”,
“args”: []
“origin”: “LOCAL”,
“time_fired”: “2021-03-14T09:47:30.986141+00:00”,
“context”: {
“id”: “e80e4647a2eab94a8c5d07a5ad92c8bf”,
“parent_id”: null,
“user_id”: null
but this could be false information because the device doesnt exists in HA, so HA took another profile.
“manufacturer”: “LUMI”,
“model”: “lumi.remote.b286opcn01”,
“class”: “zigpy.device.Device”
The same problem. Did you manage to solve this somehow?
The left version (with two double buttons) works for me with this blueprint.
Thank you very much for your efforts.
Please tell me. I imported your blueprint.
Configuration error, what could be the problem?
The screenshot is hidden under the spoiler.
Pretty certain there shouldn’t be quotes around ‘remote’ on line 201
Worked like a champ right away. thanks!
I can see the same behaviour only the left 3 buttons working the right once are not
I had the same issue. After pairing the remote for the first time i had 1_single, 2_single etc. But after repairing it with HA once it suddenly changed to on, off, etc. I could fix it by opening the device in ZHA and choose for ‘reconfigure device’. After that i had 1_single, 2_single again.
I was using it for a while and I updated home assistant to latest version and now hold in doesnt work. all the other functions work normaly expect the hold in, I cant figure why is this. I guess it has to do with a change to event
Edit: so i found the problem, looks like on the newer version the long press is replaced with hold. so go and replace all the long press with hold on event == 1(button number)_long press
Your blueprint is working great, do you guys use ‘Hold in’ to increase or decrease brightness of for example HUE lamp?
Can somebody explain how to dim with button press and hold?
Nice job! Now am I missing something or does this not recognize grouped devices under zha? (i.e. light.breezeway_lights_zha_group_0x000c created by zha containing 6 light bulbs). I don’t see this entity being listed in the devices selection drop down. (or any of my zha group entites)
@Dixey, this will be your solution:
Action type=Service
Service=Light: Turn on
Pick entity=light.breezeway_lights_zha_group_0x000c
good luck!
Can somebody help me with dimming? I tried the following, but it does not work. It does not change the state of the helper “input_boolean.light_switch_stube_ost_dimming”
Thanks for helping
Gilbert
here my blueprint code:
alias: New Automation
description: ''
use_blueprint:
path: Jarne_Roussard/aqara-opple-6-buttons-for-zha.yaml
input:
button_bottom_left_hold_in:
entity_id: input_boolean.light_switch_stube_ost_dimming
- repeat:
until:
- condition: state
state: 'on'
sequence:
- service: light.turn_on
entity_id: light.stube_zha_group_0x0005
brightness_pct: -10
button_bottom_left_hold_release:
- service: input_boolean.turn_off
remote: 8e9a6107950d4d20b871d40aa2e8d36d
I have found the error. The blueprint is not correct:
In the blueprint you have to change all long-press events:
- conditions:
- '{{ event == "3_long press" }}'
to this one:
- conditions:
- '{{ event == "3_hold" }}'
And then restart HA.
Did you update the blueprint with these changes?
Nope. How can i do that?
Temporaly i changed the blue print in my local Installation
