The blueprint isn’t picking up my Opple remote - dropdown box just says “No matching devices found”. I’ve got the same model switch that the author was using (lumi.remote.b686opcn01), this has been added and showing up in deconz, i’ve even been able to create an automation to switch a light on with a press of one of the buttons - and this is successful.
Anything i could be doing wrong? Does it need to be named in a certain way for the blueprint to pick it up?
I fixed it in my local installation, to make the hold in function work (again).
Here’s the corrected version:
blueprint:
name: ZHA - Aqara Opple - Wireless Scene Switch 6 Button
description: Control anything using Aqara Opple six button remote
domain: automation
input:
remote:
description: Opple remote to use
selector:
device:
integration: zha
manufacturer: LUMI
model: lumi.remote.b686opcn01
button_top_left_single_press:
name: Top left button - Single press
description: Action to run on a single press of the top left button
default: []
selector:
action: {}
button_top_left_double_press:
name: Top left button - Double press
description: Action to run on a double press of the top left button
default: []
selector:
action: {}
button_top_left_triple_press:
name: Top left button - Triple press
description: Action to run on a triple press of the top left button
default: []
selector:
action: {}
button_top_left_hold_release:
name: Top left button - Hold release
description: Action to run when top left button was held in and released
default: []
selector:
action: {}
button_top_left_hold_in:
name: Top left button - Hold in
description: Action to run when top left button is held in
default: []
selector:
action: {}
button_top_right_single_press:
name: Top right button - Single press
description: Action to run on a single press of the top right button
default: []
selector:
action: {}
button_top_right_double_press:
name: Top right button - Double press
description: Action to run on a double press of the top right button
default: []
selector:
action: {}
button_top_right_triple_press:
name: Top right button - Triple press
description: Action to run on a triple press of the top right button
default: []
selector:
action: {}
button_top_right_hold_release:
name: Top right button - Hold release
description: Action to run when top right button was held in and released
default: []
selector:
action: {}
button_top_right_hold_in:
name: Top right button - Hold in
description: Action to run when top right button is held in
default: []
selector:
action: {}
button_middle_left_single_press:
name: Middle left button - Single press
description: Action to run on a single press of the middle left button
default: []
selector:
action: {}
button_middle_left_double_press:
name: Middle left button - Double press
description: Action to run on a double press of the middle left button
default: []
selector:
action: {}
button_middle_left_triple_press:
name: Middle left button - Triple press
description: Action to run on a triple press of the middle left button
default: []
selector:
action: {}
button_middle_left_hold_release:
name: Middle left button - Hold release
description: Action to run when middle left button was held in and released
default: []
selector:
action: {}
button_middle_left_hold_in:
name: Middle left button - Hold in
description: Action to run when middle left button is held in
default: []
selector:
action: {}
button_middle_right_single_press:
name: Middle right button Single press
description: Action to run on a single press of the middle right button
default: []
selector:
action: {}
button_middle_right_double_press:
name: Middle right button Double press
description: Action to run on a double press of the middle right button
default: []
selector:
action: {}
button_middle_right_triple_press:
name: Middle right button triple press
description: Action to run on a triple press of the middle right button
default: []
selector:
action: {}
button_middle_right_hold_release:
name: Middle right button Hold release
description: Action to run when middle right button was held in and released
default: []
selector:
action: {}
button_middle_right_hold_in:
name: Middle right button Hold in
description: Action to run when middle right button is held in
default: []
selector:
action: {}
button_bottom_left_single_press:
name: Bottom left button - Single press
description: Action to run on a single press of the bottom left button
default: []
selector:
action: {}
button_bottom_left_double_press:
name: Bottom left button - Double press
description: Action to run on a double press of the bottom left button
default: []
selector:
action: {}
button_bottom_left_triple_press:
name: Bottom left button - Triple press
description: Action to run on a triple press of the bottom left button
default: []
selector:
action: {}
button_bottom_left_hold_release:
name: Bottom left button - Hold release
description: Action to run when bottom left button was held in and released
default: []
selector:
action: {}
button_bottom_left_hold_in:
name: Bottom left button - Hold in
description: Action to run when bottom left button is held in
default: []
selector:
action: {}
button_bottom_right_single_press:
name: Bottom right button - Single press
description: Action to run on a single press of the bottom right button
default: []
selector:
action: {}
button_bottom_right_double_press:
name: Bottom right button - Double press
description: Action to run on a double press of the bottom right button
default: []
selector:
action: {}
button_bottom_right_triple_press:
name: Bottom right button - Triple press
description: Action to run on a triple press of the bottom right button
default: []
selector:
action: {}
button_bottom_right_hold_release:
name: Bottom right button - Hold release
description: Action to run when bottom right button was held in and released
default: []
selector:
action: {}
button_bottom_right_hold_in:
name: Bottom right button - Hold in
description: Action to run when bottom right button is held in
default: []
selector:
action: {}
source_url: https://community.home-assistant.io/t/aqara-opple-6-buttons-for-zha/261418/39
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input 'remote'
- variables:
event: '{{ trigger.event.data.command }}'
- choose:
- conditions:
- '{{ event == "1_single" }}'
sequence: !input 'button_top_left_single_press'
- conditions:
- '{{ event == "1_double" }}'
sequence: !input 'button_top_left_double_press'
- conditions:
- '{{ event == "1_triple" }}'
sequence: !input 'button_top_left_triple_press'
- conditions:
- '{{ event == "1_release" }}'
sequence: !input 'button_top_left_hold_release'
- conditions:
- '{{ event == "1_hold" }}'
sequence: !input 'button_top_left_hold_in'
- conditions:
- '{{ event == "2_single" }}'
sequence: !input 'button_top_right_single_press'
- conditions:
- '{{ event == "2_double" }}'
sequence: !input 'button_top_right_double_press'
- conditions:
- '{{ event == "2_triple" }}'
sequence: !input 'button_top_right_triple_press'
- conditions:
- '{{ event == "2_release" }}'
sequence: !input 'button_top_right_hold_release'
- conditions:
- '{{ event == "2_hold" }}'
sequence: !input 'button_top_right_hold_in'
- conditions:
- '{{ event == "3_single" }}'
sequence: !input 'button_middle_left_single_press'
- conditions:
- '{{ event == "3_double" }}'
sequence: !input 'button_middle_left_double_press'
- conditions:
- '{{ event == "3_triple" }}'
sequence: !input 'button_middle_left_triple_press'
- conditions:
- '{{ event == "3_release" }}'
sequence: !input 'button_middle_left_hold_release'
- conditions:
- '{{ event == "3_hold" }}'
sequence: !input 'button_middle_left_hold_in'
- conditions:
- '{{ event == "4_single" }}'
sequence: !input 'button_middle_right_single_press'
- conditions:
- '{{ event == "4_double" }}'
sequence: !input 'button_middle_right_double_press'
- conditions:
- '{{ event == "4_triple" }}'
sequence: !input 'button_middle_right_triple_press'
- conditions:
- '{{ event == "4_release" }}'
sequence: !input 'button_middle_right_hold_release'
- conditions:
- '{{ event == "4_hold" }}'
sequence: !input 'button_middle_right_hold_in'
- conditions:
- '{{ event == "5_single" }}'
sequence: !input 'button_bottom_left_single_press'
- conditions:
- '{{ event == "5_double" }}'
sequence: !input 'button_bottom_left_double_press'
- conditions:
- '{{ event == "5_triple" }}'
sequence: !input 'button_bottom_left_triple_press'
- conditions:
- '{{ event == "5_release" }}'
sequence: !input 'button_bottom_left_hold_release'
- conditions:
- '{{ event == "5_hold" }}'
sequence: !input 'button_bottom_left_hold_in'
- conditions:
- '{{ event == "6_single" }}'
sequence: !input 'button_bottom_right_single_press'
- conditions:
- '{{ event == "6_double" }}'
sequence: !input 'button_bottom_right_double_press'
- conditions:
- '{{ event == "6_triple" }}'
sequence: !input 'button_bottom_right_triple_press'
- conditions:
- '{{ event == "6_release" }}'
sequence: !input 'button_bottom_right_hold_release'
- conditions:
- '{{ event == "6_hold" }}'
sequence: !input 'button_bottom_right_hold_in'
Thanks to [gilbert-grape] for pointing out the necessary changes!
How can we update the original blueprint? Or should i post a new one?
The original blueprint triggers systematically an action twice for each event.
I d’ont know if it’s due to my setting or if it’s the same for all users.
If I associate a permute/toggle action to a button it will not work as it will double trigger causing the switch being in its original state.
I found a workaround by modifying the blueprint.
Forcing single mode worked for me mode: restart to mode: single in the blueprint
I’m not seeing double actions and have been testing with the toggle on light and switch entities here.
Very nice little remote for one-shot actions, but I just discovered that none of the buttons support repeating. That means this thing is somewhat useless for use with dimmers or volume control. Can anyone recommend any other Zigbee models that have working repeat?
I don’t suppose there are any solutions/workarounds for this behaviour? I’ve found this thread after setting up very similar hold-to-dim/brighten functionality via Node-Red. It seems like a bit of a disappointing cop-out (from the manufacturer, not you @visstro) to say that the release event only works as expected for a particularly short hold event. All I’ve come up with so far is using a step of 20% and interval of 1s so that the full brightness range is covered and a timeout can be forced after 5s.
blueprint:
description: "Control anything using Aqara Opple six button remote"
domain: automation
input:
remote:
selector:
device:
integration: zha
manufacturer: LUMI
# ---------------------------- BUTTON TOP LEFT ----------------------------
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
# ---------------------------- BUTTON TOP RIGHT ----------------------------
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
# ---------------------------- BUTTON MIDDLE LEFT ----------------------------
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
# ---------------------------- BUTTON MIDDLE RIGHT ----------------------------
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
# ---------------------------- BUTTON BOTTOM LEFT ----------------------------
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
# ---------------------------- BUTTON BOTTOM RIGHT ----------------------------
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
default: []
selector:
action: {}
mode: restart
- platform: event
event_data:
device_id: !input "remote"
- variables:
event: "{{ trigger.event.data.command }}"
- choose:
- conditions:
sequence: !input "button_top_left_single_press"
- conditions:
sequence: !input "button_top_left_double_press"
- conditions:
sequence: !input "button_top_left_triple_press"
- conditions:
sequence: !input "button_top_left_hold_release"
- conditions:
sequence: !input "button_top_left_hold_in"
- conditions:
sequence: !input "button_top_right_single_press"
- conditions:
sequence: !input "button_top_right_double_press"
- conditions:
sequence: !input "button_top_right_triple_press"
- conditions:
sequence: !input "button_top_right_hold_release"
- conditions:
sequence: !input "button_top_right_hold_in"
- conditions:
sequence: !input "button_middle_left_single_press"
- conditions:
sequence: !input "button_middle_left_double_press"
- conditions:
sequence: !input "button_middle_left_triple_press"
- conditions:
sequence: !input "button_middle_left_hold_release"
- conditions:
sequence: !input "button_middle_left_hold_in"
- conditions:
sequence: !input "button_middle_right_single_press"
- conditions:
sequence: !input "button_middle_right_double_press"
- conditions:
sequence: !input "button_middle_right_triple_press"
- conditions:
sequence: !input "button_middle_right_hold_release"
- conditions:
sequence: !input "button_middle_right_hold_in"
- conditions:
sequence: !input "button_bottom_left_single_press"
- conditions:
sequence: !input "button_bottom_left_double_press"
- conditions:
sequence: !input "button_bottom_left_triple_press"
- conditions:
sequence: !input "button_bottom_left_hold_release"
- conditions:
sequence: !input "button_bottom_left_hold_in"
- conditions:
sequence: !input "button_bottom_right_single_press"
- conditions:
sequence: !input "button_bottom_right_double_press"
- conditions:
sequence: !input "button_bottom_right_triple_press"
- conditions:
sequence: !input "button_bottom_right_hold_release"
- conditions:
sequence: !input "button_bottom_right_hold_in"
are more people bothered by adding their aqara opple switches? I need several times to add it properly to get the buttons visible as a trigger. if it is added incorrectly it will get the name:
unk_manufacturer unk_model
and if it is added correctly it will be called:
LUMI lumi.remote.b686opcn01
now I had added all switches correctly, but 4 jumped to the bad name, so that the buttons no longer work.
My switch was in the wrong mode (dimming/color temp etc); I messed around removing / re-adding etc but couldn’t make it switch.
Eventually I got it to work. The last thing I did before it worked was to do 3 quick presses (ie: not a hold) on the bind button and then reconfigure. No idea if that was the critical piece of the puzzle or not… but thought I’d share.
If anyone else tries, do report back if it worked for you!
I am having a problem, my device is not showing in the blueprint.
It is connected via Zigbee2MQTT which is connect to ZHA ZBBridge Tasmota.
The section of “Remote Opple remote to use” is empty.
I removed all blueprints from me because I also had the problem that they didn’t work and made the automation normal and it works without any problems.
