Aqara Opple 6 Buttons For Zha
I also experience problems with the Aqara Opple 6 Button Switch.
The initial setup worked just fine, but after i restarted my Rasp-Pi, all the device information was gone and the Buttons did not work as expected. Now when i re-pair the device, it seems like only the upper 4 Buttons generate any events, but they dont distinguish between the different types of presses (single/double …) Here is a screenshot of the events triggered by the upper four buttons
Using the template to call any service doesnt work, how matter which button i choose.
I would be happy if someone could help both with the setup problem and the data loss problem when restarting.
Hello, if you use Zigbee&mqtt then the switch will work without any blueprints.
I used the following blueprint for Zigbee2MQTT:
After some tries, the Blueprint works fine for my ZHA Integration as well. Thanks Vispatel!
The blueprint is installed and it works fine.
But i dont know how to make a long press for dimming a light.
Need help for this. step by step.
I do not understand what exactly to do with this item: Helper - Last Controller Event[​
I use blueprint from 2 years. Now, from 4 days, it no work anymore.
I see automation log, and it work, utl choose condiction, but not go away
Did you fix your problem looking for the same issue?
