Aqara Opple and pysical switch -> Shelly
hello,
to control my shelly with a pysical button works good. now
i ve a Aqara Opple and want also switch my shelly with it.
but i ve no idea, how i must configurate HA. need help. thx
need help!!!
perhaps with node red and a IF function?
IF AQARA IS PRESSED AND SHELLY = ON THEN SHELLY = OFF
IF AQARA IS PRESSED AND SHELLY = OFF THEN SHELLY = ON
Possible to make this with NodeRed?
What integration are you using? ZHA?
i use Zigbee2mqtt
I don’t have any knowledge regarding Aqara Opple with Zigbee2Mqtt, but I think you use device trigger for your automation (modify the trigger below)-
  - device_id: ad44cabee4c646f493814306aa6446e1
    discovery_id: 0x000b57fffecb472d action_arrow_left_click
    domain: mqtt
    platform: device
    subtype: arrow_left_click
    type: action
condition: []
  - service: >-
      light.turn_{{'on' if is_state('light.your_light', 'off') else 'off' }}
      entity_id: light.your_light
like this?
  - platform: device
    device_id: ''
    domain: 'mqtt'
    entity_id: 'sensor.scheune_schalter_action'
condition: []
  - service: >-
      light.turn_{{'on' if is_state('light.shelly_shsw_1_e8db84acb1b1', 'off') else 'off' }}
      entity_id: light.shelly_shsw_1_e8db84acb1b1
and, where can i add which buttons was pressed (1 or 2)?
I think the trigger is incorrect. As I don’t have any idea about Z2M button click trigger, you can read more about it here-
Install MQTT-explorer, connect it to your broker and press your buttons. Post what you received here.
Your trigger will need to be something like
  - platform: mqtt
    topic: zigbee2mqtt/opple/action
  condition:
    condition: template
    value_template: '{{ trigger.payload_json[''TRIG''] == ''SINGLE'' }}'
this?
this will also not work:
  - alias: Scheune Licht Innen
      platform: mqtt
      topic: 'zigbee2mqtt/Scheune Schalter/action'
    condition:
      condition: template
      value_template: '{{ trigger.payload_json[''TRIG''] == ''button_1_single'' }}'
      service: light.turn_{{'on' if is_state('light.shelly_shsw_1_e8db84acb1b1', 'off') else 'off' }}
try
      platform: mqtt
      payload: 'button_1_single'
      platform: mqtt
      service: >-
If the template is single line, you will need to add quotes. If it multi lines, then you don’t need.
works. :wink:
thx
second wish
i ve another AQARA OPPLE (6 buttons). Try this both code here, to control the volume of my media player. but both dont work
  - alias: Volume Minus
      platform: mqtt
      topic: 'zigbee2mqtt/Partyraum Schalter/action'
      payload: 'button_5_single'
      delay:
        seconds: 0.1
      entity_id: media_player.denon_partyraum
      service: '{{ states.media_player.denon_partyraum.attributes.volume_level - 5 }}'
  - alias: Volume Plus
      platform: mqtt
      payload: 'button_6_single'
      delay:
        seconds: 0.1
      data_template:
        volume_level: '{{ states.media_player.denon_partyraum.attributes.volume_level + 5 }}'
  - delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
  - service: media_player.volume_set
      volume_level: >-
        {{ state_attr('media_player.denon_partyraum', 'volume_level') - 0.1 }}
If the above YAML doesn’t work, try-
      volume_level: >-
        {{ '%.1f' | format(state_attr('media_player.2f_bedroom_tv', 'volume_level') - 0.1) }}
Lastly, just a suggestion, you should add a condition to only allow automation proceed if media_player.denon_partyraum is ON as otherwise you will get an error as usually media_player does not have volume_level attribute when they are OFF-
condition:
  - condition: state
    state: 'on'
