I am wondering where i could change the interval / delay of the reset of the occupancy detection for aqara P1 motion detector.
After initial installation the interval is set to 10 minutes but i can not find where to change this interval for example to 3 minutes. The use case is that want to control a light with the occupancy detection but the ligh should only be on for 3 and not for 10 minutes.
Where can i find the attribute tot setup to change the reset of the occupied sensor within 3 minutes and not 10 minutes.
Thanks for your help.
Have you tried using the Motion detection option, instead of Occupancy? That has a 15 second minimal activity window.
Yes I have had. This option only configures how long no detection of movement can be triggered. It does not have any effect on the time delay in which the occupancy switches back to unoccupied after occupied status. This time delay stays 10 minutes.
If you utilize an automation that reacts to the MOTION in the sensor, you can forget all about how the habits of OCCUPANCY works.
Yes I know and for the time being I have realized it with a timer and an automation. But this is only a workaround in my opinion. The detector has a function for occupancy and in this case I want to use it. ![]()
I’ve accepted how it operates by default with ZHA, as I don’t want to add an Aqara hub or get involved with Zigbee2MQTT. If there are ways one can manage the ZHA device (Device Info, Manage Zigbee device: Clusters, Bindings, etc.), I’m not aware.
