Aqara P1 will not connect
I have a Conbee II stick and use ZHA. i have multiple units on the network all have worked fine. i also have older P1’s that connects just fine, now i bought 4 new ones, and they just don’t show up when i try to connect them.
any ideas what could be wrong?
they light up as they should when i press the reset button for 5 seconds.
Bumping this as I have exactly the same problems.
Just bought two new P1’s. Not able to connect to ZHA at all. No issues with the 6 other P1’s I have of older date.
@Rene54321 Are you able to provide a production date? On the box my new P1’s came in, the little sticker on the packaging says production date 06/2023.
Edit: I’m on ZHA with a Sonoff ZBDongle-P
I just received a few Aqara P1 motionsensors. They won’t pair with HomeAssistant Zigbee2Mqtt and Sonoff dongle Plus.
Next day I managed to pair the devices: I put the device very near to a router, then in Zigbee2Mqtt Permit join (that router), then press button on the back of the device for 5 seconds. Then the device paired.
I have the Sonoff Zigbee Dongle P as coordinator and also could not pair Aqara P1 motion sensor using Zigbee2MQTT.
I found that to reliably pair them you need to select one zigbee router (or your coordinator) that is within easy reach, bring your Aqara sensor very close (almost touching) to the router and press and hold the reset button on the Aqara sensor. Count for 5s and in Zigbee2MQTT click “Permit Join ()” (pairing process through that specific router and not another one) to start the Zigbee2MQTT pairing process at the same time the Aqara sensor enters pairing mode (blue LED flashing). After that you can release the button.
I managed to pair 5 Aqara P1 motion sensors in a row whereas i tried for an hour before that.
Thanks! That fixed it for me as well. Maybe the P1s are having trouble choosing from the vast number of routers we have. I didn’t have the issue when only a few routers were in the vicinity.
Thanks, that worked for me - had to hold it very close the coordinator and only start Pairing in Z2M when the blue lights started flashing on the P1. Just be careful not to keep holding the pair button on the P1 after it starts flashing blue - it will reset for a 2nd time otherwise.
ty so much :smile:
Worked like a charm
I had this issue recently with MQTT. I had to have the P1 flash blue and then as soon as it did click permit join all. If I was permitting before it flashed or too late after it never seemed to work.
Having tried and failed to join a pair of Aquara P1’s (Aqara RTCGQ14LM control via MQTT | Zigbee2MQTT) I gave up on them a year ago. I tried again yesterday and kept trying, low and behold they finally joined the network. The timing seemed to be crucial, if I permitted joining shortly before or after the final blue flash on the P1 it failed. When I synced enabled joining with/immediately after the last blue flash it worked. Bizarre how finicky these are!
Thank you VERY much… I was banging my head off the wall trying to figure out what had seemingly changed on its own. I added a dozen Third Reality Zigbee lightbulbs, not realizing they had built in routers… Now that I initiated a new device right next to the coordinator… Bingo. You’re the best.
Where and how can you select exactly which router to pair too. I don’t see that capability but would love to be able to do that… Thanks.
-Gil
-Gil
OK hey guys, I wanna share my discovery because I was banging my head all arvo yesterday trying to connect a P100 sensor to my vanilla Zigbee2MQTT + Mosquitto setup on a Linux machine using the Zigbee 3.0 USB Dongle Plus (ZBDongle-E).
I tried all these solutions/workarounds from people posting here NOTHING worked I was literally about to start purchasing other sensors or I thought the battery was wasted but its blinking and everything when I hold 5S etc so I was getting really frustrated alright.
It turns out that the P100 is a dual-protocol device that ships in Thread mode by default, and you have to actively switch it to Zigbee before it can pair with the Zigbee coordinator. The protocol can be switched by Bluetooth via the Aqara Home app WITHOUT any Aqara hub.
All I did was download the Aqara Home app > Added a device via the Magic QR which is located on the device and or the booklet that came with your sensor and once you get it paired with Bluetooth via the Aqara Home app you can switch protocols to Zigbee and there you have it Bob's your uncle! I then proceeded to Permit Join in Zigbee2MQTT UI and just like that it got paired. I was like no frigging way that worked! :partying_face:
When you’re ready to pair a device in Z2M… Before you click on the permit join button, click on the down arrow just to the right of it. It allows you to select which device you want to pair with. I never knew it was there either, but it’s an awesome feature. When I add a device downstairs, I check the LQI, looking for the most robust device in the area and choose it to bind to.
-Gil
