Aqara Roller Blind/Shade - Showing as Light & Position not working
Finally got around to installing the Aqara roller blind via Samsung Smarthings.
However, it’s showing at a Light sensor.
This works. I had to configure the ‘open’ and ‘closed’ position on the Aqara device first.
So if on=open
off=closed
I’m running 2022.6.6 but “Switch as X” isn’t available?
Is it possible to change that?
Also the ‘Position’ of the blind/shade doesn’t work, but displays correctly.
It displays ‘open’ and ‘closed’ - however, I can’t set it to 50%… But I can in the Smartthings App.
Anybody else had similar issues?
I’m thinking of creating a Virtual Button in Smartthings that sets the blind/shade to 50%.
So the Virtual Button will feed to to Home Assistant, when pressed, will run a routine in Smarthing to set the Blind/Shade to 50%.
