I’m having a problem with the E1 on ZHA. I could previously set the position between 0-100 using the analog_output cluster, but in a recent release this has stopped working due to the maximum value being incorrectly reported as 0. It should be 100.
Yes it still works for me.
I am on Home Asistant 2022.5.4 and the maximum value for my number.lumi_lumi_curtain_acn002_analog_output entity is falsely reported as 1023 not like in your case as 0.
As I have added another abstraction level (template cover entity), that prevents moving the shade if the windows behind it are open this false maximum does not affect me, but it would be annoying otherwise.
I had the same problem where the up and down buttons were not working and greyed out. It did work with the analog control option, but I wasn’t happy with that.
I upgraded my Conbee 2 stick with the latest firmware, then removed the device and re-added it in the ZHA integration and it worked immediately.
I followed this guide and I flashed deCONZ_ConBeeII_0x26780700.bin
Hope this helps some of you.
I just tried updating the firmware of the Conbee 2. It does not delete the stored network. Unfortunately, removing and readding the E1 did not change anything… up and down arrows still greyed out
Strange…
Did you follow the calibration steps of the unit ? >>> does pressing the physical down and up buttons on the device once stop automatically at the desired positions?
I have recently bought 2 additional E1 to the previous 4 I already use and I’ve noticed something new after pairing in ZHA.
For all 4 previous E1 I’ve created the virtual cover as described in this thread. They work, but none of them exposes battery level obviously.
Now, after pairing one of the new E1 I got more sensors for the device and one of them is battery. I’ve checked the E1 is using quirks: “zhaquirks.xiaomi.aqara.roller_curtain_e1.RollerE1AQ” and it works correctly without the need for virtual cover.
However, when I paired the second new E1 it behaved as the previous ones. No battery sensor and steering doesn’t work. I also re-paired one of the older E1 and there is no change.
So my question is what could be the reason that one od E1 is configured with the above quirks and how to make the other E1 use them as well?
EDIT: Both E1 have the same firmware and I also updated one for the older units but still only one E1 is with mentioned quirks.
I have 2 of these working perfectly and 2 newer ones with the problem mentioned above. the ones that work report firmware 0x00000e19 and the newer ones are reporting 0x00000e1b in home assistant.
Updated the conbee firmware and tried unpairing and re pairing but i cant get them working at all.
