Is the direction on the roller shade driver is set up correctly? (So pressing the down buttin on the device itself lets roll the shade down and the up-button lets it roll up accordingly? If you not you need to switch motor direction on the E1.
Usually the direction is greyed out when the shade driver already is in that positon (either top or bottom and the position state reports 0% or 100%)
Thanks, the thing is, the manual I received is in Chinese - seems walmart.com is selling the ones from China. Don’t really know what the series of buttons is.
@chris.peck Look here, the guy has described the calibration process in his article.
The steps are (copied from the article above):
Calibration is very easy. Click the “up” and “down” buttons simultaneously for 3 seconds, until the blue LED comes on. Then we put the blind in completely open position, using the “up” button, stop it and confirm it by pressing this button 5 times. The blue LED will flash 3 times.
We lower it until it is completely closed and confirm again by pressing the “down” button five times. There should be 3 flashes again.
Has anyone got this to work with Sonoff Zigbee 3.0 USB dongle? I don’t have a Aqara hub. The pairing worked fine but I get the same greyed out direction button as descibed above and all I can do is move the motor in one direction, either with the active direction button or with the analogue selector. The stop works though!
I have just purchased the E1 blind motor and it is set up with zigbee2mqtt and working fine. My only problem is now getting the calibration process to work so that it knows when it gets to the top or bottom and knows when to stop. Since I dont have an aqara hub (I am using a sonoff zigbee dongle) the process to do the calibration described by @anon94216691 is not open to me. Any suggestions?
That’s a purely individual choice. I’m running Zigbee2MQTT for my living area Zigbee mesh and ZHA for my Garage mesh (on a dedicated coordinator (CC2652 LAN-Gateway).
Both do the job most of the time but I like Zigbee2MQTT a bit better and it’s known for the huge number of supported devices - although ZHA is catching up in that area.
An afternoon of fighting 502 error, but eventually I have a working controller. I can open, open to whatever angle I like, close and I even know what the battery charge level is.
I setup the Aqara roller shade companion E1 (ZNJLBL01LM) on Z2M a couple days ago and initially everything seemed to be working properly. More recently, every now and then, the roller shade stops working with the error (Data request failed with error: 'MAC transaction expired' (240))'
I have other devices using Z2M that are working without any issues so the problem seems to be isolated only to this device. Also to note, after a while, the device works again as intended regardless of the errors still showing up in the Z2M logs. Has anyone experienced anything similar in Z2M?
FYI, using the Sonoff Zigbee 3.0 USB Dongle Plus with the firmware upgrade.
