Aqara rollershade driver stops automation
the automation of the Aqara roller blind often stops working. The automation will then not start. He does it manually. The direction has also changed without me changing anything. This often seems related to an update of HA that has just been done.
Can you share your automation?
alias: Gordijn zolder rechts omhoog
description: “”
  • type: illuminance
    platform: device
    device_id: fbb5874fe28058142d5947d7107bf37a
    entity_id: 91989e7b4781777f41a3a78ce44997b4
    domain: sensor
    above: 1500
    condition:
  • device_id: c4e0eec8edb36d8f51d3d43b0da4027f
    domain: cover
    entity_id: 190d8524966c93760fadd9390ec86196
    type: set_position
    position: 40
    mode: single
