After using my sensors for over a year for some reason the aquara sensors keep losing connection. I’ve tried multiple battery swaps and also removing them from ZHA and adding them again. But all disconnect again after a couple of days. This goes for motion-, temp-, door-sensors and also the aquara buttons.
I use a sonoff zigbee 3.0 stick and there are multiple routers in my network. But even the sensors that are just meters away from the router disconnect.
Assuming you did all the obvious things, such as an usb extension cord, check if wifi channels overlap with Zigbee (new routers or automatic channel changes, neighbors, … can all change): I added a setting to zha that seems to have eliminated all my problems. It does lower security somewhat though:
Well I did check the 2.4 wifi settings of my router. Unfortunately the tp-link x20’s I have don’t allow for manual channel switching in their settings. They do offer a smart option that scans available networks and sets the “best” possible channel.
I’ll give the security setting a try, thanks for the tip.
Those problems often gets resolved by first adding a long USB extension cable for the Zigbee Coordonation as well many more “known good” Zigbee Router devices and then after that re-pairing the Aqara/Xiaomi’s Zigbee devices again.
Usb extention cable is present. Also multiple routers. But even the sensors that are only 1 or 2 meter away from the router suffer this issue. Routers are also from different brands so that also can’t be the cause.
Everything has functioned well for 1.5 to 2 years before this issue started.
Hello everyone,
I’m a bit late with my post, but I believe I’ve found a solution to this problem. At least, it worked for me.
I have several Aqara devices in use, and recently I’ve been facing an issue where the devices regularly disconnected. I had tried pretty much every troubleshooting step I could think of.
Eventually, I discovered that Aqara devices can sometimes have significant issues with meshing. In my case, this caused massive problems because the Aqara buttons and sensors kept losing their connection while meshing.
I read that Aqara sensors and switches have a known issue where they don’t re-mesh properly. They seem to remember the point they were initially connected to and stick to it permanently.
My solution was to connect all devices either directly to the mesh controller or to a device nearby. You can see how to do this in the screenshot.
I read this with interest, as I too have never-ending problems with Aqara Zigbee sensors disconnecting, and in some cases never being able to reconnect them.
I guess my hardware is different to yours - I use a Sonoff Zigbee Bridge (Tasmota). May I ask what sort of mesh controller you use? And also which piece of software does your screenshot refer to?
They’re using Zigbee2MQTT, but you can achieve the same result in ZHA by going to the device page (for the closest device to your sensors) and clicking 3 dots > add devices via this device:
I suspect the issues you have with Aqara devices is because you’re trying to pair everything with the coordinator when there are more suitable devices nearby. Personally I never had issues with any products from this brand once I learnt to set them up the way zigbee expects.
Well I fixed my issue. But I did 2 things at the same time so I can’t 100% say wich solved it. I changed my controler from the Sonoff zigbee 3 version to the Skyconnect/Connect ZBT-1. And I also changed from ZHA to Z2M.
The move over was quite a bit of work but worth it. I have the idea me network is a lot more reliable than it was with ZHA, no disconnects for a couple of weeks. Also updating firmware works a lot better than before, where ZHA failed 100% of the tries to update my ikea lamps and remotes Z2M completed each update on the first try without failure.
The most stable way to make Aqara devices stick is to use an M2 hub (I say that because it is the cheapest and you aren’t using it for features anyway) and connect the devices directly to it. Then generate a matter code via the M2 hub and move the hub and devices in via matter. Almost all devices will come over. Then you can integrate them into automations and they will never fall off. With the Aqara hub connected via Ethernet along with your HA equipment the control stays local and is not cloud dependent.
Hello, sorry for being late. Garfieldtt connects the Aqara devices directly to the zigbee USB dongle instead of using any other meshes/repeaters. It makes the connection with the device more stable because Xiaomi/Aqara devices use a different mesh system making things more complicated.
If you use Zigbee2Mqtt can connect your device directly to the coordinator by clicking the on the dropdown menu next to permit join and selecting coordinator. Like mentioned here
If you use ZHA you can achieve the same result by going to your coordinator in devices selection, clicking the 3 dots and selecting add devices via this device. Like mentioned here Aqara sensors keep disconnecting - #9 by ShadowFist
I was dealing with dropping Aqara sensors for years before finally finding this thread. I had just purchased a ZBT-2 figuring that since Nabu Casa was behind it, it might work best with HA. But after changing that out for the Zigbee/Zwave stick I was using the Aqara devices were still dropping at the same rate.
I was done dealing with it and was starting to look at replacing all of the Aqara devices with much more expensive devices but figured I’d do one last search. Well, for me switching to Zigbee2MQTT was the answer and I’m extremely grateful to everyone who has posted about their experiences here. It’s been three weeks since I switched and not a single device has dropped.
If you find yourself here after searching for a fix to this problem I highly recommending ditching the ZHA add-on for the Zigbee2MQTT solution.
And if you develop for HA, it might be worth looking into why the ZHA add-on doesn’t work the same way. It’s most likely the add-on that would be used for someone just starting with HA and I’d hate for that to be the reason why someone gave up on it.
Yeah, I use the ZHA add-on and have encountered lots of problems with pairing AQARA devices with it. I did not switch to Zigbee2MQTT since all my other 29 Zigbee devices have been rock solid using ZHA. However, I did pair all my AQARA devices to the AQARA hub and used the HA HomeKit Device add-on to see the hub and all 36 of my AQARA devices. That has also been rock solid even though it now requires the AQARA hub.
My apologies been away for a while. Yes, that is another zigbee network. However, I have 4 separate zigbee networks. Home Assistant with Z2M on channel 11, Aqara Channel 15, Hubitat channel 20, a beta development Hubitat hub channel 25. Wifi is channel 11 main router in home, outside access point channel 6, building access point channel 1 (Home Assistant overlaps yes but physical separation is fairly a long way).
I have absolutely zero issues with zigbee and wifi interference and all my zigbee meshes perform strong with no issues. The key is to have lots of repeaters on each mesh.
