Aqara sensors on ZHA always say 100% of battery reaming
Hello everyone,
I have the following detail that is somewhat annoying, since several versions back from home assistant, my aqara sensors always report 100% battery, I really do not remember which was the last version where the battery level was displayed correctly, but it was More than 8 months ago, as I mentioned in the beginning, they worked fine without problem, and in each update of the home assistant I hope it will be fixed, but it has not happened.
It happens to someone else or they have an idea of what configuration I should review so that they operate correctly, attached image of a pair of them both should be below 60% life …
Did you figure it out?
Any news here? I observe the same problem. Aqara sensors (temp, door) that I’ve paired a long time ago were correctly reporting battery levels. For a number of months they now show 100%. Aqara sensors that I paired recently, report battery levels <> 100%. Running Conbee II.
