Hi All,
I use an Aqara smart plug and ConBee 2 Stick.
Somehow the graph of the power consumption is not correct:
As far as I understand the lower value should be 0 but not ~0.3.
Can someone help me to understand where to look at to find an issue?
Consumption should always increase, so something doesn’t look right. Maybe try deleting it and adding again. I have 3 aqara plugs and they all look ‘normal’.
Hi Michael,
Thanks for the info.
I reset the plug and now the graph looks like the following:
The graph now seems to be correct, but when I assign this plug to the Energy consumption dashboard, the dashboard sum all values instead of picking the last value.
Any idea how to make the Energy dashboard work with Aqara plug correctly?
The problem is that looks more like a power graph (ie. kW) rather than consumption (kWh). For example, this is the power for my air fryer:
It’s only going from 0 to 1 and back because I haven’t used it recently. But here is the consumption:
As you can see, it’s always going higher and higher as it is used. Do you get both power and consumption entities created?
Yes I have both, but somehow they report data differently than yours:
