I have a Xiaomi Aqara switch that I want to toggle on/off a light source.
I have set up this in my automations.yaml
When I press the Aqara switch nothing is happening. Can someone plase help?
- alias: Test toggle light
platform: event
event_type: xiaomi_aqara.click
event_data:
entity_id: binary_sensor.switch_158d000201c99b
click_type: single
service: light.toggle
entity_id: light.fibaro_system_fgd212_dimmer_2_level_2
The indentation has been corrected. The automation is on.
When I trigger the automation in “states” in home assistant it works. But when I press the Aqara switch button nothing is happening.
The Aqara button is paired in Deconz. When I look at it in VNC it reacts (blinkling blue) when I press the button.
If you’re using deconz the entit_id will not be like that and you need to trigger on a deconz_event. I asume you switched from the xiaomi gateway?
Check the docs. implementation with Deconz is slightly different but the docs explain how to do it.
Have you ensured that you have the right event type?
Normally if you are running this through Deconz, the event type is deconz_event. See below a simple trigger I’m using on a aqara button through deconz.
Hello
I did not have the correct event type. deconz_event works!
I have another strange behavior right now. I have two of thees Aqara switches, and have set up two automations controling different lights each.
But when I click one of the buttons both lights are toggled. This is the same for both buttons. What am I doing wrong now?
I have not made any associations in Phoscon. The switches and the light.lys_spisestue have just been added normally. The fibaro unit at the bottom of the automation is offcourse z-wave.
Google is not going to help, there is definitely something you’re missing in your configuration. Carefully check your automations and scripts. I assume you are no longer using the Xiaomi gateway?
I never had the Xiaomi gateway, it was a mistake from my side to use the wrong event_type. I’m using a Raspbee on my Raspberry Pi3 with deconz.
I will try to comment out the automations one by one to see what happens.
Not sure about this, but I havn’t seen any entity_id’s that contains dots after the domain, i.e. remote.b1acn01, it is usually underscores as in remote_b1acn01.
I think the name is correct for the switches.
From what I have read in the forums is that under deconz_event it should be id: not entity_id:
I changed my automation but now it is not working at all.
ok, if you have these entity_id’s in the dev-state panel, it shoud be correct, I just have never seen entity id:s like that. My deconz entities all have underscores instead.
