Hi! I bought an Aqara E1 Double Gang No-Neutral(QBKG38LM) and I am trying to use it in decoupled mode with an automation that toggles the lights(4 Wi-Fi) that are connected to the same circuit.
The switch only triggers when the lights are on or after a few seconds they are off.
I am using Zigbee2MQTT and looking at the logs, I see no errors.
LQI of 236. The switch is in the same room with the coordinator(sky connect). There are 10 router devices. looking at the z2m map 6 of them don’t look connected though. I’n not sure if that’s ok.
here’s the map:
Ah, you’re triggering of the mqtt event. Typical that should be fine, but try this and see if it’s any better:
- platform: state
entity_id:
- sensor.kitchen_light_switch_2_action #I don't know the name of your device
attribute: action
to: single_top #actions are single_top, single_bottom, double_top, double_bottom
- service: light.toggle
entity_id: light.cave
data: {}
mode: single
This will toggle the light and let it decide how to handle it internally (rather than you having to check it).
Regarding your map… Those wouldn’t happen to be Ikea GU-10s, would they? Typically they should all be router devices connected to the coordinator, however, depending on how old the firmware is on them, they may have dropped off your mesh. Do you get anything like “Failed to get LQI for ” when generating the map?
The automation does not work at all now, it never get triggered.
And yes, they are Ikea GU-10s. I tried OTA while they are connected but it’s says there is no updated available.
There is also something weird with these lights combined with another Aqara 2 gang no neutral. I have the same setup and when turning the lights on from the switch, after a few seconds the switch turns off.
This sounds more like a signal problem to me. If I’m understanding correctly, you hit the rocker and it toggles on and then a few seconds later toggles off?
So, first thing I would try to do is re-pair the GU-10s and see if they stay connected to the coordinator (or a router closer to them). Same thing for your “Switch | Cave” rocker and see if it connects properly to the mesh.
Does anything show up in the logbook? I’m having a hard time imaging that the rocker won’t process anything if the light is off unless it’s wired up weird? (I’m in the US, so my wiring might be a bit different than yours).
Ahhhhh… ok, now we’re getting somewhere. Try this:
alias: New automation
description: ""
- platform: state
entity_id:
- sensor.switch_cave_action
attribute: action
to: single # I guess your version just uses single?
data: {}
mode: single
Yeah, that leads me to believe that the wiring might be wrong. It almost feels like that hot wire is coming from the light rather than the load. TBH, I’m not sure So, when the light is off, if you look at Z2M, does it show the switch as available?
I have 6 of the US rockers (both neutral and non-neutral) and none of them work that way at all.
Uhhhh, nope. That doesn’t look right at all. That means that the last seen attribute isn’t setup. In Z2M, Settings (top bar), go to the Advanced tab and scroll down and set what I have in the screen shot. That will at least give you the last_seen attribute. You can also setup the Availability in the availability tab, but one thing at a time.
Once that is setup (I believe you have to restart Z2M for that setting), then we can troubleshoot why the switch doesn’t respond when the light is off (still boggles my mind).
If a no neutral switch only works when the light is on. it might be that you need a bypass cap/resistor across the bulb to allow more power thru to the switch.
“There are 4 lights”, so that shouldn’t be a problem, but I suspect something like that could be going on as well.
Before the current switches, I used wifi ones which required this capacitor. I assumed this was only the case for wifi switches. I will try installing it again see if it works. Thanks!
