Aqara Temp Hum Sensor refresh rate issue with deconz usb stick
Hi all,
It is my first topic . Im using home assistant for simple installation so i didnt have any bigger issues before.
I was using deconz stick for about year with deConz addon . Everything works fine .
I changed to zigbee2mqtt now and seems to works better but …
One of my Aqara Temp Hum Sensor ( Xiaomi WSDCGQ11LM ) have a problem with refresh rate (refresh every 1-3 sec)
It is very weird because another same sensor is working perfectly (about 5 mins or more)
I tried to use Reporting tab but it seems to not working
Error Request 'zigbee2mqtt/bridge/request/device/configure_reporting' failed with error: 'Bind 0x00158d000582879b/1 msTemperatureMeasurement from '0x00212effff0615ff/1' failed (waiting for response TIMEOUT)'
Or i did that no correctly .
Thank you for any ideas.
I don’t know if they actually support changing the reporting rate, none of mine are configured with a reporting rate. However if you want to try, at the same time as you send the command, you need to press the little button on the Temperature device to wake it up.
Thank you Andrew for suggestion .
Im not sure what was the main issue .
I did like you said and then too long intervals wasa problem ;p no change for few mins even with 5 degree changes .
unpair and 1st try to repair . and during 3rd try to repair i change battery . everything works fine now .
Have no idea what fix issue but it works now
Thank you again :slight_smile:
My best guess as I had several sensors like yours is that is a normal behavior when they are close to end the battery. So when that happens you have 1-2 days of battery. By the way it is the best way to end the battery make it report each 5 seconds (irony off)
