Aqara temp sensor and zigbee2mqtt: I can see in the log, but nothing else
hello
I finally received my new aqara temp sensor… unpacked, hold the button and hoped to see the new entity/device under the configuration, but nothin :frowning:
check the homepage/dashboar, but nothign :frowning:
looked into the zigbee2mqtt edge log and magically see the followings:
zigbee2mqtt:info 2021-01-31 22:43:10: MQTT publish: topic 'homeassistant/sensor/0x00158d0001d72638/linkquality/config', payload '{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/0x00158d0001d72638","json_attributes_topic":"zigbee2mqtt/0x00158d0001d72638","name":"0x00158d0001d72638_linkquality","unique_id":"0x00158d0001d72638_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d0001d72638"],"name":"0x00158d0001d72638","sw_version":"Zigbee2mqtt 1.14.1-dev","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}
how do I see the item to the homepage/dashboard?
You could try manual configuration, if autodiscovery doesn’t work.
Thank you, I will look into that :slight_smile:
