I took 3 Aqara temperature sensors and they keep disconnecting me like 1 time a day, I have to enter on zha delete them and re-add them. What could be the problem? the signal of all 3 is between 90 and 100. In the same rooms I also have 3 aqara motion sensors and I’ve never had a problem with them. Ideas?
What do the logs say? Is a Battery Level involved? Do they need the cloud (Internet traffic/site issues? Does it need more boosters (powered) to relay to hub.
Log: Attribute Updated event was fired
the battery level changes every time i plug it in but its always above 80%
they are local but I use an automation that serves to align the offset of the Tado thermostatic valves (they are in the cloud)
Did you get any where with this? I bought 4 recently and two wouldn’t connect… then when they finally did they disconnect and stay disconnected after a few hours. Now a third is dropping out too!
I contacted Aqara and they said that they’re not compatible with the SkyConnect dongle which seems ridiculous since they’re Zigbee devices.
Did you manage to fix the problem?
