Aqara temperature sensor shows wrong temperature values for subzero temperatures in HomeKit
Aqara temperature sensor added automatically via G2H HomeKit camera hub shows wrong temperature values for subzero temperatures. Like 90 or 80 degrees instead of -1 or -2 Celsius degrees. While at the same time values visible in Aqara Home App are correct.
I am seeing this issue also. The temperature may be 20c but has multiple drops per day to -50c. Did you find a fix for this?? Thanks
Hello
I have the same issue. Did you find a way to fix it ?
Regards
