Aqara TRV occupied_heating_setpoint is changing by itself
I’m trying to use my Aqara TRV in a pretty straightforward way: set it into the manual heat mode with maximum occupied_heating_setpoint 30deg. I know that it will not heat so much because the main not smart thermostat is set to 19deg. In other words, I just want to fully open/close the radiator valve in my room with HA. In the morning when I wake up I see that it is still in the heat mode but occupied_heating_setpoint is set to 5 deg. Did anybody face with similar problem?
This is the maximum value that the setpoint can be. I limit that to 22°C so that it can’t be changed to a higher value manually.
You need to modify occupied_heating_setpoint to select the actual setpoint.
